Bulb failure light
- deka
Bulb failure light
Hi. Just replaced the rear light cluster due to the leds failing, is there away I can clear the light failure warning on the dash
E89 2.5I Blue rubbish wheels
Gone But not forgotton. Z4 06 roadster 2.5 Midnight blue Hardtop black heated leather, stubby, phone kit, 108's PDC. ZHP
- Smartbear
Bulb failure light
Hi, the dash warning should extinguish when the fault is removed?
You could have a high resistance connector if the lights still on but all lights are working?
e85 3.0si sold
Bulb failure light
When disturbed my rear lights some of the stop lamps blew. Check them.
- deka
Bulb failure light
Thanks guys All the bulbs are ok I will take it apart agin and make sure all the connections are tight
