noise from rear of vehicle
- Smelf36
So I have noticed on a couple of occasions, a strange metallic sort of 'hissing/scraping' noise coming from the rear of the car.
it is very intermittent, for example I heard it today for the first time in about a week! seems to be from the back nearside and if you dip the clutch and blip the throttle it goes away until you take your foot back off the throttle (clutch engagement does not alter the noise). there are no drive/fueling issues that I can detect, no clutch slip, its not brake squeal and they work fine, in fact the car drives perfectly. No warning lights. Could it be some sort of valve in the exhaust?? just the increased revs made me wonder.
Then 2008 E85 2.0i Sport roadster.
Now 2012 E89 2.0i M Sport
Live every day like it's your last, cos one-day you'll be right
you may have a small piece of gravel stuck between the disc and the backplate!
Mark
Plymouth
E89
35i
Carmine Red
Black leather
Plymouth
E89
35i
Carmine Red
Black leather
- Smelf36
I’m pretty sure it’s not brake related, mainly as it goes away when the Revs are increased?
- Nictrix
The problem with a lot of cars is sometimes a noise sounds like it is coming from the rear when it is actually the front.
Do you hear this noise with the roof up, down or both?
We had a slight noise that was like a whirring/hissing that could be heard with the roof down and I also thought it was from the rear.
The only thing I could find was the coolant was low and I put the noise down to it being the water pump that I could hear.
I havnt heard it again since.
Sorry, just re reading your post. If its related to engine revs and no difference with clutch engaged/disengaged then its your engine.
Does it do it when the vehicle is parked or only when moving?
Mark
Plymouth
E89
35i
Carmine Red
Black leather
Plymouth
E89
35i
Carmine Red
Black leather
- Smelf36
only when moving so far, never had a petrol engine with a turbo before, could it be this?mcbutler wrote: ↑Mon Aug 19, 2019 8:38 amSorry, just re reading your post. If its related to engine revs and no difference with clutch engaged/disengaged then its your engine.only when moving so far, never had a car with a turbo before, something to do with that ??
My thought is wastegate rattle, but you saying it sounds like it’s coming from the N/S rear is a bit baffling, but as Nictirx said sound can carry in strange ways in cars. Flip the bonnet, from the front listen to the left side of the engine.
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
Or a loose exhaust silencer baffle on the N/S pipe.
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
Let the dog out of the boot couldn’t resist
- Smelf36
Waste gate valve? I know nothing about turbo’s, is this a big problem? I noticed today that the valve in the right hand tail pipe is open on tick-over, I thought this only opened above 4000 revs to give more noise? Is this right, could this have anything to do with it???
Oh and the dogs in the wife’s boot, he wouldn’t lay down long enough to shut the lid in the Zed
- Smelf36
Not really a baffle kinda rattle, had that before, more of a hissing sort of noise, really hard to describe?
Hi smelf36 sorry about joke hope you solve the issue.*
- Smelf36
No need for apologies be good to fix it, although it’s doesn’t seem to be a major issue, car runs and stops fine, just a bit irritating at times
Blowing exhaust perhaps..? Not very likely as it’s a stainless system but worth a shot. Let it idle and put a hand over each tailpipe, you’ll hear it blowing as well as there won’t be much back pressure on your hand.
Wastegate rattle could be the rod linkage has worn causing the rattle, or maybe the wastegate is leaking but you’ll hear this from inside the engine bay. Did you lift the bonnet and have a listen yet? Get someone to hold the revs at increments of 1k up to around 3-4K and listen for a hiss.
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
- Zed Baron
