AutoStop/Start Not Working
Hi, noticed over the last couple of days (well since I drove it from the garage tbh), that there's an AutoStop/Start indicator with a line through it. Is that a setting that needs to be turned on, is it normal or should i get it looked at?
tbh not really fussed about stop/start unless it saves me a shed load of fuel!
BMW Z4 E89 28i - Heated everything....
Lotus Elise S MY 2007 (Crumple zone detected stationery vehicle)
Porsche Boxster
Lotus Elise 111S
Mazda RX8
VW Scirocco GTS
Honda Civic Type R
Porsche Boxster
Lotus Elise 111S
Mazda RX8
VW Scirocco GTS
Honda Civic Type R
- Smartbear
Hi, stop/start will only work when the cars fully up to temp & carrying a fully charged battery-if these criteria aren’t met it’s not operationalcre8toruk wrote: ↑Tue Jan 08, 2019 3:22 pm Hi, noticed over the last couple of days (well since I drove it from the garage tbh), that there's an AutoStop/Start indicator with a line through it. Is that a setting that needs to be turned on, is it normal or should i get it looked at?
e85 3.0si sold
On some cars (Volvo XC70) it also needs outside air temp to be above a certain figure even with a fully charged battery and oil up to temp..
OnlineMr Tidy
Be grateful it's off!
My only experience of it on a 1 Series included a new battery after just over 4 years and a new starter motor after just over 6 years. After that I turned it off every time I used the car!
It's a hateful invention.
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
- ronk
Don't worry - The system hasn't worked on our 335xd for weeks either - there are conditions that have to be met before it works - Temperature/Battery level for starters (no pun intended)
Personally I don't like it and I don't think it saves any significant amount of fuel.
- Smartbear
It’s possible to code this function with Carly so it remembers its last selected state instead of defaulting to “on” every time the car’s started
e85 3.0si sold
Vidi, vici, veni
- ronk
I didn’t realise they fitted it to the E89 - My 2016 35is doesn’t and nor did my previous 2010 3.0l have it fitted.
Be glad it doesn't work!
- enzed4
Does it show up as an option in a VIN search?
OP, I had stop/start in a work toyotal corolla and it stopped working a while before the battery did. But as others have pointed out, the Z4 stop/start seems dependent on other factors such as temperature (and you're in the middle of winter at the moment) so it may be related to that instead.
Gone: 2010 35i DCT
Gone: 2008 2.5Si Sport
- Smartbear
The 6 cylinder cars never had it Ron
e85 3.0si sold
- ronk
As I suspected!
If it was such an environmental and fuel saving boon as they suggest, then surely the bigger engines / less economical cars would have benefited more?
- Smartbear
I suspect it might be tied in with the fact the bigger engine takes a lot more out of the battery to spin it over to start so stop/start is probably not sustainable for that reason
e85 3.0si sold
- ronk
I don’t think that’s the reason as our 335xd has a six cyl Diesel engine - I would think that would take a lot more energy to spin than the petrol alternative?
(Higher rotating mass and compression ratio)
Never mind it’s not a system I miss
Stop / Start allows the manufacturer to squeeze through the various mpg drive cycles especially the urban mode.
I guess if you are in stop start traffic crawling though a city etc it would help...
If you just stop at intersections in the countryside it’s a waste of time..IMHO..
