BMW Z4 e89 SDrive23i (2.5 litre) Sept. 2010 - Only about 36,000 miles - Intermittent low oil pressure light problem.
The car was due an oil service in December, but a couple of weeks ago the red oil pressure light came on. I stopped the car and upon restarting, it was fine and drove home OK. I had the oil service done, but a few days later the light came on again (again it was fine after stopping and restarting - no obvious bad engine noise). I then had the oil pressure switch replaced with genuine BMW part. Fine for a few days and maybe 50 - 60 miles in a variety of driving conditions, but last night it came on again. As usual, I stopped and restarted and all was fine. Anyone any ideas as to what I do now?
Oil pressure warning light?!?!
- Smartbear
What does the electronic dipstick say the level is?Mattt wrote: ↑Sun Dec 02, 2018 11:13 am BMW Z4 e89 SDrive23i (2.5 litre) Sept. 2010 - Only about 36,000 miles - Intermittent low oil pressure light problem.
e85 3.0si sold
Switch? Or sensor? And who did the work? The same guy who did the previous and recent oil services?I then had the oil pressure switch replaced with genuine BMW part
Vidi, vici, veni
- Mattt
Oil level on max.
Work was carried out by local reputable BMW Specialist including services etc.
- Mattt
Switch and sensor the same thing on this no?
Switch part no. B21.61.7.549.796 replaced.
An oil warning light is never good. Take it to a garage you trust.
Vidi, vici, veni
- Mattt
No leaks, no top ups have been required - it stays on max.
Sensor replaced with brand new OEM.
It’s going back next week, will see what the codes say.
- Mattt
Indy confirmed codes were 30C1 and 30C4 - pointing to oil pressure control fault.
It’s going into Main Dealer for them to check actual pressures - which the Indy says he can’t do.
- Phil40
Hi, i have the same probleme. Anyone have found a solution ?
E89 2011 Sdrive 23i manual Sapphire Black - France (sorry for my english level not perfect)
