Help - rough running 35is
Hi all,
I was driving the z4 yesterday, put my foot down and as he car dropped a few gear it suddenly started running very lumpy and EML light came on. Parked up, went shop. Came back out and the car was running fine, on my journey home I thought I would try and put the foot down again, on,y to be greeted with the same reaction from the car, lumpy running, EML light.
Anyone have any thoughts on diagnosis?
35is 2010 with 60k on the clock
Z4 3.0l - gone
650i - gone
Z4 35is - gone
M4 - Current
650i - gone
Z4 35is - gone
M4 - Current
- ph001
High pressure fuel pump. You need to read codes to make sure though as could be a coil pack but I would have a small bet on the former.
Spark plugs always a cheap place to start...120 for a set of 6, fitted by bmw...
- ph001
...or £44 for set of 6 fitted by yourself. Very simple job and at least you stand a chance of it been done right:
https://www.ebay.co.uk/itm/Genuine-Bosc ... 2917834347
I’ve had this issue. Was HPFP
Same, high pressure fuel pump.
2011 X3 30d MSport black, 8-speed auto, leather everything
2011 Bimmer Z4 35i diamond black, 6-speed manual, full caboodle (hibernating)
What costs were you looking at for the HPFP??
What spark plugs do you guys use? Any cold iridium ones, or just standard?
Cars booked in for Monday with a Indy near me
Z4 3.0l - gone
650i - gone
Z4 35is - gone
M4 - Current
650i - gone
Z4 35is - gone
M4 - Current
Also, I’ve seen online some reports BMW extended the warranty on the HPFP to 10 years or 100k. Can anyone report if this is correct and if so if they’ve had any luck with getting it fixed through bmw?
Z4 3.0l - gone
650i - gone
Z4 35is - gone
M4 - Current
650i - gone
Z4 35is - gone
M4 - Current
- Smartbear
Hi, I think that was for the American market only & no such luck over here in the ukLil_g_1234 wrote: ↑Wed Nov 28, 2018 3:28 pm Also, I’ve seen online some reports BMW extended the warranty on the HPFP to 10 years or 100k. Can anyone report if this is correct and if so if they’ve had any luck with getting it fixed through bmw?
Same sort of double standards regarding cracked wheels I believe...
e85 3.0si sold
This ^^^Smartbear wrote: ↑Wed Nov 28, 2018 4:02 pmHi, I think that was for the American market only & no such luck over here in the ukLil_g_1234 wrote: ↑Wed Nov 28, 2018 3:28 pm Also, I’ve seen online some reports BMW extended the warranty on the HPFP to 10 years or 100k. Can anyone report if this is correct and if so if they’ve had any luck with getting it fixed through bmw?
Maniac wrote: ↑Wed Nov 28, 2018 7:50 pmThis ^^^Smartbear wrote: ↑Wed Nov 28, 2018 4:02 pmHi, I think that was for the American market only & no such luck over here in the ukLil_g_1234 wrote: ↑Wed Nov 28, 2018 3:28 pm Also, I’ve seen online some reports BMW extended the warranty on the HPFP to 10 years or 100k. Can anyone report if this is correct and if so if they’ve had any luck with getting it fixed through bmw?
Well that’s s**t! Fingers crossed for spark plugs then
Z4 3.0l - gone
650i - gone
Z4 35is - gone
M4 - Current
650i - gone
Z4 35is - gone
M4 - Current
Mine did the exact same thing..2012 35IS and it was a single coil packLil_g_1234 wrote: ↑Thu Nov 22, 2018 10:59 am Hi all,
E89 S Drive 35iS
Just had a call from the Indy, misfire on 2 & 5. 5’s coil pack has some oil on it (suspected from oil being spilt while topping up, as all valve gaskets are fine, previous owner... ). So we’re replacing both, just because Christmas is coming so the Indy could do with the extra work (I’m guessing) and new spark plugs. Fingers crossed that sorts it! I’m just relieved it’s not the injectors! Indy said my injectors are working fine, which is nice to knowHunter wrote: ↑Sun Dec 02, 2018 5:02 pmMine did the exact same thing..2012 35IS and it was a single coil packLil_g_1234 wrote: ↑Thu Nov 22, 2018 10:59 am Hi all,
Z4 3.0l - gone
650i - gone
Z4 35is - gone
M4 - Current
650i - gone
Z4 35is - gone
M4 - Current
Nice one, i was almost 100% sure that was all it was going to be. forums are great but tend to throw up the worst possible outcome if a fault is posted when 99% of the time its an easy fix. Its a bit like self diagnosing a medical complaint, the net says your going to die, but you just have wind and need a good fartLil_g_1234 wrote: ↑Mon Dec 03, 2018 12:32 pmJust had a call from the Indy, misfire on 2 & 5. 5’s coil pack has some oil on it (suspected from oil being spilt while topping up, as all valve gaskets are fine, previous owner... ). So we’re replacing both, just because Christmas is coming so the Indy could do with the extra work (I’m guessing) and new spark plugs. Fingers crossed that sorts it! I’m just relieved it’s not the injectors! Indy said my injectors are working fine, which is nice to knowHunter wrote: ↑Sun Dec 02, 2018 5:02 pmMine did the exact same thing..2012 35IS and it was a single coil packLil_g_1234 wrote: ↑Thu Nov 22, 2018 10:59 am Hi all,
E89 S Drive 35iS
Oh and i advise doing the throttle response procedure when you get the car back, look under the heading of "Hesitation" for the how to do it.
E89 S Drive 35iS
