Handbrake warning light and disc warning light has come on together in yellow on the dashboard, and cruise stopped working. When i switch the ignition off a large park warning sign comes on in the dashboard.
Any ideas
Handbrake and disc warning light has come on in yellow on the dashboard ,and t
Online
Could be faulty abs sensor on one of the wheels.
Check your battery condition. From what I've read on the forum, these type of faults often come down to a dodgy battery not being fully charged.
- Angie4m
If your handbrake is no longer working it will have been caused by a low battery. The code usually shows up as a failed wheel speed sensor and the only way to have this sorted is to have the software updated by BMW or a specialist. It cost about £125 from BMW to get it done.
Just a word of advice, if you have a USB in the glove box ensure that this is unplugged prior to the updates being made. I left mines in and the garage couldn't get the updates to take until the USB was removed.
Deep Sea Blue sDrive35is - I LOVE IT! Best car I've ever owned - Gone
RRS V8 Supercharged - Gone
Abarth 595 Competizione - Gone
Yas Marina Blue M4 Coupe - Gone
Current:
Protonic Blue i8
Amethyst 997
F56 JCW Challenge (19 of 52)
Still Shy and retiring
Current:
Protonic Blue i8
Amethyst 997
- ronk
Thats a chargeable event?Angie4m wrote: ↑Fri Sep 28, 2018 10:48 pm If your handbrake is no longer working it will have been caused by a low battery. The code usually shows up as a failed wheel speed sensor and the only way to have this sorted is to have the software updated by BMW or a specialist. It cost about £125 from BMW to get it done.
So Dick Turpin lives if we have to pay to correct BMW flakey software.
- Angie4m
Yup and the worst but is depending on the dealer they might not just take your word for it and instead insist that they need to do an inspection first so charge around £162 minimum at current rates to determine that is the issue and then charge for the coding.ronk wrote: ↑Fri Oct 05, 2018 12:06 amThats a chargeable event?Angie4m wrote: ↑Fri Sep 28, 2018 10:48 pm If your handbrake is no longer working it will have been caused by a low battery. The code usually shows up as a failed wheel speed sensor and the only way to have this sorted is to have the software updated by BMW or a specialist. It cost about £125 from BMW to get it done.
Fortunately there is two different dealerships in Edinburgh, one will do whatever you ask because if it doesn’t resolve the issue they know it’s not their fault but the other won’t just change a part or perform an update at a customers rewurst, they want to charge a small fortune for investigation work. And prices vary widely between the two so who knows what other dealerships are charging.
Current:
Protonic Blue i8
Amethyst 997
Current:
Protonic Blue i8
Amethyst 997
