E89 Roof Question
E89 Roof Question
Don’t think it’s a problem as such, might be just the battery.
I can open the roof with my key by holding down the open button, same as many of us, however although I keep my finger on the button the roof stops half way thought the action always at the same point, I first thought it might be the battery as the car isn’t running but it still does it after a long run and the same point ,
As such this isn’t an issue as it works fine with the engine running but any feedback would be appreciated.
Toys: Z4 E89 35i in Blue / Ducati Multistrada 1260 DVT + love my watches
E89 Roof Question
What if you do it from the button in the car?
10-plate E89 35i, Deep Sea Blue
67-plate F15 X5 35d, Space Grey
E89 Roof Question
Are you standing in the same spot every time (I assume you are opening on the key from outside)?
I find that if I stand close to the back of the car the roof itself seems to 'get in the way' of the signal. From the side or front appears to be better.
G29 S30i in SFR - my wife's car and her third Z
BMW M2C - gone, replaced with an i4, but its only use is shopping, the Z is our main touring vehicle
Long gone, but not forgotten - 1988 E30 M3
E89 Roof Question
Works fine from the button in the car, it’s just when I use the key
E89 Roof Question
If that's the case then I'd hazard a guess that it's related to the signal from the key getting to the car, rather than anything the car is (or isn't) doing...Frankie169 wrote: ↑Mon Sep 03, 2018 6:44 pm Works fine from the button in the car, it’s just when I use the key
Do you have a second key? If so, what happens when you use that one?
E89 Roof Question
I had a similar issue when my roof went completely haywire. Even after the roof motor and control module change if i used the key to open it 40% chance it got stuck. Then stopped again. Thank god everythings fixed now and hasnt failed me for months with probally over 100s of uses. It might be worth while changing the two relays, Near the hydrualics module in the boot. One relay controls one movement being bringing it down and another relay controls bringing it back up. Try atleast checking them swapping them around or replacing them with brand new ones as a precautionary there like 12 quid a pop and you can do it yourself
E89 Roof Question
Adil_3 wrote: ↑Tue Sep 04, 2018 3:05 pm I had a similar issue when my roof went completely haywire. Even after the roof motor and control module change if i used the key to open it 40% chance it got stuck. Then stopped again. Thank god everythings fixed now and hasnt failed me for months with probally over 100s of uses. It might be worth while changing the two relays, Near the hydrualics module in the boot. One relay controls one movement being bringing it down and another relay controls bringing it back up. Try atleast checking them swapping them around or replacing them with brand new ones as a precautionary there like 12 quid a pop and you can do it yourself
Couldn’t do us a favour and take a photo on the relays and the position, am going to check the movement using both the keys first then if still a problem will play with the relays
E89 Roof Question
My apologies for the delay, i shall send them over to you later on today once ive finished work.Frankie169 wrote: ↑Tue Sep 04, 2018 6:20 pmAdil_3 wrote: ↑Tue Sep 04, 2018 3:05 pm I had a similar issue when my roof went completely haywire. Even after the roof motor and control module change if i used the key to open it 40% chance it got stuck. Then stopped again. Thank god everythings fixed now and hasnt failed me for months with probally over 100s of uses. It might be worth while changing the two relays, Near the hydrualics module in the boot. One relay controls one movement being bringing it down and another relay controls bringing it back up. Try atleast checking them swapping them around or replacing them with brand new ones as a precautionary there like 12 quid a pop and you can do it yourself
E89 Roof Question
Adil_3 wrote: ↑Thu Sep 06, 2018 10:28 amMy apologies for the delay, i shall send them over to you later on today once ive finished work.Frankie169 wrote: ↑Tue Sep 04, 2018 6:20 pmAdil_3 wrote: ↑Tue Sep 04, 2018 3:05 pm I had a similar issue when my roof went completely haywire. Even after the roof motor and control module change if i used the key to open it 40% chance it got stuck. Then stopped again. Thank god everythings fixed now and hasnt failed me for months with probally over 100s of uses. It might be worth while changing the two relays, Near the hydrualics module in the boot. One relay controls one movement being bringing it down and another relay controls bringing it back up. Try atleast checking them swapping them around or replacing them with brand new ones as a precautionary there like 12 quid a pop and you can do it yourself
Thanks, you're a star
E89 Roof Question
I had a similar issue for a time, didn't bother me too much as it was just coming out of winter.Frankie169 wrote: ↑Sun Sep 02, 2018 8:24 am Don’t think it’s a problem as such, might be just the battery.
However after a little scratching and trial and error I figured it out to be a battery issue. After a decent drive it would work fine, couple of days later - problem again. Just replaced battery and haven't worried since.
Mind you, it didn't always stop in the same place...
Silver E89 Sdrive30I Msport. Black roof and other bits.
E89 Roof Question
Frankie169 wrote: ↑Thu Sep 06, 2018 1:21 pmAdil_3 wrote: ↑Thu Sep 06, 2018 10:28 amMy apologies for the delay, i shall send them over to you later on today once ive finished work.Frankie169 wrote: ↑Tue Sep 04, 2018 6:20 pm
https://drive.google.com/file/d/1EDWkfl ... sp=sharing
heres the link for the relays. Its the two orange ones, located next to the battery in the boot. Hope it helps for trouble shooting
E89 Roof Question
[/quote]
[/quote]
Thanks, really appreciate it, going for a decent run this weekend so will try it out after the key battery and car battery are fully charged and see what happens
[/quote]
[/quote]
