Oil Warning
- ronk
Oil Warning
A few have said that their gauges go down in segments - but it was suggested that they "don't do that now sir"
or is that another wriggle?
I’ve asked BMW customer service to confirm.
- Mr Tidy
Oil Warning
Hmm, you could do with getting a reply from someone who has an E89 as new as yours.
The ones on my E86 and E91 definitely go down in segments - there are 4 markings from one end of the scale to the other.
If what you are being told is correct that seems a pretty cr*p "update" to an already pretty cr*p system!
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
Oil Warning
Well, unless someone can devise an after-market dipstick, we're stuck with 'Bong & Add oil', aren't we?
Vidi, vici, veni
- Smartbear
Oil Warning
So did your electronic dipstick not move at all & all you got was the bong?
e85 3.0si sold
Oil Warning
Morning, Rob.
Yes, the e-dipstick moved, but I never found it a good enough indicator, even though the car's parked on spirit-level-flat concrete, so measuring liquids should be easy.
I experimented: hot engine, park, read indicator, add oil, drive to re-heat engine & oil, park, read indicator and so on. A right pita and the indicator responded poorly.
The 'bong and add a litre' is easier and avoids the danger of over-filling.
(I had a 911 with an e-dipstick. Each segment was 125ml and it was accurate. The car also had a proper dipstick, so you could avoid over-filling.)
Vidi, vici, veni
- ronk
Oil Warning
I’m sure that the add 1l now warning does avoid over filling but I am nor enthusiastic about driving around short of oil.
Ok pottering about bit I’m on the Autobahn on Monday and likely not pottering!
- ronk
Oil Warning
It would be one litre under maximum before it warned me!
I wouldn’t normally drive around under max
- ronk
Oil Warning
If a litre isn’t short - what would you consider is?
- ronk
Oil Warning
I don’t understand your logic why 125miles after the boing -
It’s taken 6.5k use a litre so another 1000 miles will only use an extra 0.15 litre
Oil Warning
You said that you "... wouldn’t normally drive around under max." You're being unnecessarily cautious.
MIN on the dipstick, electronic or manual, is the point at which you put in oil. (Indeed, on some models Jaguar tell owners explicitly not to put in oil until the level reaches MIN.)
Continually topping up to MAX is a waste of time and can easily lead to overfilling.
So, you're fine bombing down the autobahn at 250kph - until you hear the bong. Then you've got 200km to put in the litre you're carrying in the boot.
Simples.
Simples.
Vidi, vici, veni
- ronk
Oil Warning
I’m sure Bmw logic is just that ie to help prevent over filling and looking at the volume of the sump, a single litre wont make a huge % difference.
I suppose I’m just old school
Thanks for reminding me about the ‘boing’ tho - I have the speed warning on I drive set to 80mph and I would rather not let on to Mrs K that we are moving much faster. Build up to 100mph then creep up when I can.
Ps Germany on Monday.
