Brakes very hot
keving1
Brakes very hot
Post by keving1 » Mon Jul 23, 2018 9:07 am
I noticed at the weekend that all the 4 brakes on my 35i were very hot after a gentle 4 mile drive, over 100 degrees centigrade :o .
Is this normal as I haven't noticed this before (or maybe not checked before)? No warning lights or fault codes.
Smartbear
Brakes very hot
Post by Smartbear » Mon Jul 23, 2018 9:20 am
keving1 wrote: Mon Jul 23, 2018 9:07 am I noticed at the weekend that all the 4 brakes on my 35i were very hot after a gentle 4 mile drive, over 100 degrees centigrade :o .
You say gentle, are there many downhill sections or junctions on your route?
I don’t think it would take much use to get the brakes that warm :?
e85 3.0si sold
keving1
Brakes very hot
Post by keving1 » Mon Jul 23, 2018 9:50 am
I would have braked gently about 20 times from 30-40mph each time.
Busterboo
Brakes very hot
Post by Busterboo » Mon Jul 23, 2018 9:54 am
How did you measure them?
Vidi, vici, veni
keving1
Brakes very hot
Post by keving1 » Mon Jul 23, 2018 10:07 am
I was in the middle of washing the zed when I had to go out to get something for the wife and when I came back washed the wheels, with the water being sprayed on the discs turning to clouds of steam :o
RustyZ4
Brakes very hot
Post by RustyZ4 » Mon Jul 23, 2018 5:20 pm
If its a manual, have you tried just cruising in neutral to see if the brakes are binding? if not it could be just its so bloody hot at the moment, I had a dust covering on my car, so thought I would rinse it off, there was steam coming off my car and no I had not driven it.
Z4 E85 3.0, gone but now with son :D
Busterboo
Brakes very hot
Post by Busterboo » Mon Jul 23, 2018 10:11 pm
keving1 wrote: Mon Jul 23, 2018 10:07 am I was in the middle of washing the zed when I had to go out to get something for the wife and when I came back washed the wheels, with the water being sprayed on the discs turning to clouds of steam :o
So, not with a pyrometer, then.
Vidi, vici, veni
Silverzedtom
Brakes very hot
Post by Silverzedtom » Mon Jul 23, 2018 10:39 pm
All sounds normal to me :thumbsup:
E85 2.5si
F55 Cooper S
keving1
Brakes very hot
Post by keving1 » Tue Jul 24, 2018 8:28 am
Silverzedtom wrote: Mon Jul 23, 2018 10:39 pm All sounds normal to me :thumbsup:
Thanks for the replies, looks like all is normal.
keving1
Brakes very hot
Post by keving1 » Tue Jul 24, 2018 8:32 am
Busterboo wrote: Mon Jul 23, 2018 10:11 pm
No using Science, water boils and turns to steam at 100 degrees centigrade :rofl:
Busterboo
Brakes very hot
Post by Busterboo » Tue Jul 24, 2018 9:23 am
keving1 wrote: Tue Jul 24, 2018 8:32 am
Indeed, it does. Indeed, it does. That is not a measurement, however, of the temperature of your discs. :)
Vidi, vici, veni
keving1
Brakes very hot
Post by keving1 » Tue Jul 24, 2018 9:49 am
Busterboo wrote: Tue Jul 24, 2018 9:23 am
What is it a measure of then, as the heat is produced by the discs and pads :?
TomK
Brakes very hot
Post by TomK » Tue Jul 24, 2018 11:32 am
I have measured my discs at 620c, this will also turn water into sream :D
ihadablackdog
Brakes very hot
Post by ihadablackdog » Tue Jul 24, 2018 11:48 am
If we’re going to be pedantic, the op didn’t say they were 100 degrees...he said they were over 100 degrees.
Regardless, the question he is asking is, should the brakes get hot enough to turn water to steam?
2011 E89 sDrive20i
Busterboo
Brakes very hot
Post by Busterboo » Tue Jul 24, 2018 1:37 pm
OP, TomK's post is the best answer in this thread.
Discs & the surfaces of pads can become very hot - a long way above 100C - and, yes, they'll turn water to steam.
Vidi, vici, veni
