Knocking Noise...
Knocking Noise...
Good Evening all!
Bit of a unknown here and i confess to being a total n00b at times with stuff like this... but... help is required!
I own a 2013 Z4 2.0i in valencia orange - beautiful car - however it recently had a slight whine from my engine.
I had assumed it was a bearing on (probably) the tensioner of the belt, however a few weeks ago - whatever was broken went bang!
Car seems to drive fine (although I confess the little i've driven it has resulted in the noise getting slightly worse...)
I've attached a video for the noise,
Your thoughts and advice is much appreciated... the BMW stealers want £2000 just to look at it - and not guaranteeing a fix at that! THe car itself has done 52,000 miles...
https://youtu.be/ZRGhFmtCbOc
1st... E85 2.0i... stupidly sold it because I needed a "work car"
2nd... E89 SDrive 2.0... thurst bearing failure rendered the engine useless
3rd... E89 2.3i... The Doner engine for the 2nd... the transplant has begun!
Knocking Noise...
The BMW dealers "want £2000 just to look at it." Two thousand? Surely not.
Whatever, just take it to any good garage.
Vidi, vici, veni
Knocking Noise...
Yup, a full day to strip the engine, (£900)
then a full day to put it back together (£900)
Not even a fix in there... Sad times
Knocking Noise...
That really doesn't sound right to me...
10-plate E89 35i, Deep Sea Blue
67-plate F15 X5 35d, Space Grey
- Smartbear
Knocking Noise...
Avoid bmw & find a good Indy garage, I think you’re bill would be higher than that by the time they’ve added gaskets/coolant/oil etc
There’s no way I’d be driving the car with it sounding like that, I wouldn’t even start it again.
e85 3.0si sold
- GBZ4
Knocking Noise...
Really don’t like the sound of that, I agree with Busterboo, any good garage should be your first port of call
2016 E89 18i Roadster - gone and forgotten
- RustyZ4
Knocking Noise...
+1
Z4 E85 3.0, gone but now with son
- Chris_D
Knocking Noise...
Damn that sounds scary!
Sack main dealers off. Get urself over to a good indy.
Hope its a simple fix....
Knocking Noise...
Just a thought is it possible to run the engine with the drive belt detached, could the noise be alternator, air con or tensioner related?
After all no different than if it had snapped.
I had a bearing go on a TR7 alternator, made a right racket.
Knocking Noise...
Thanks guys,
Yea the car is now with my usual independent! He is going to have a look at it and see what he thinks! - I'll keep you posted.
Agree car doesnt sound great, but strangely doesnt seem to make much noise at low revs. although makes a bit more noise when it starts cold...
Sadly looks like i'll be getting rid of it - hopefully without too much of a financial hit!
Knocking Noise...
Hopefully not just because of the knocking noise? I'm sure it's fixable..
