Loose connector
Loose connector
My apologies for asking this question in the newbies intro section, I'm new. Looking under the bonnet of my zed I noticed this loose connector, I've looked all over and I can't find its other half, anyone point me in the right direction please.
- 20180612_182839.jpg (327.22 KiB) Viewed 766 times
- 20180612_182852.jpg (269.66 KiB) Viewed 766 times
- 20180612_182857.jpg (293.58 KiB) Viewed 766 times
Loose connector
Sorry wrong place again, Mr moderator could you please put this in right place, I just saw problems , mine is an E 85/6 not sure how do you tell?
- markplant
Loose connector
Could be from bonnet switch for alarm which should be where the 2 diagonal bars meet
- markplant
Loose connector
Like this
- markplant
Loose connector
Just to add if it is from the bonnet switch, these tend to get in un plugged if the alarm is false alarming as it's the usual culprit, so you may need a switch, or leave unplugged
Loose connector
Thanks for the quick reply, mine doesn't have the alarm connection there. It may well be just a part of the loom that isn't used, or the connection has dropped down, and I can't see it. Just seemed a bit to clean for it not to have been joined to something.
- 20180612_194139.jpg (424.81 KiB) Viewed 748 times
- Smartbear
Loose connector
As previously mentioned, it should have the bonnet sensor there so looks like it’s been disconnected & removed
e85 3.0si sold
