No Boost - Help!!
john-e89
No Boost - Help!!
Post by john-e89 » Sat May 05, 2018 6:19 pm
Smartbear wrote: Sat May 05, 2018 6:09 pm
john-e89 wrote: Sat May 05, 2018 4:38 pm
SteveSmith wrote: Sat May 05, 2018 4:30 pm Should it move freely when not running??
Yes, it’s just mechanical. The actuator is vacuum operated but it should all move freely.
Hi John, I don’t think these are vacuum operated? The earlier cars had one like that but the lci models went to a solenoid activated wastegate. :?
Yes I think you’re correct on that Rob.... :oops: My mistake. Sorry Steve, wrong year.
Cheers Rob, good spot, my bad.
MR2 MK 2
E89 35is
G29
Smartbear
No Boost - Help!!
Post by Smartbear » Sat May 05, 2018 6:52 pm
No worries John, I think most of us learn something new about these cars every time we look on the forum :)
e85 3.0si sold
SteveSmith
No Boost - Help!!
Post by SteveSmith » Sat May 05, 2018 6:56 pm
Does this mean it shouldn’t move then?
28i M Sport - Alpine White / Canberra Beige, 19" M359’s, H&R’s / Eibachs, BMS Stage 1 - 271bhp, Front Splitter, CF Rear Lip, Alcantara Steering Wheel and Brembo 4 pots
john-e89
No Boost - Help!!
Post by john-e89 » Sat May 05, 2018 7:13 pm
SteveSmith wrote: Sat May 05, 2018 6:56 pm Does this mean it shouldn’t move then?
If it is electronic then no, you’re not pushing against a vacuum as in the earlier cars. Sorry, I got the wrong year.
MR2 MK 2
E89 35is
G29
ronk
No Boost - Help!!
Post by ronk » Sat May 05, 2018 11:03 pm
Waste Gates op mechs have changed a lot over the years .
The Saab turbo was operated by exhaust gas pressure on top of a diaphragm!
suttz83
No Boost - Help!!
Post by suttz83 » Thu May 17, 2018 1:49 pm
Do you have fault codes? Common problems with these are the diverted valves/boost solenoids (they seem to have a number of names). If they are faulty they can fail with the wastegates stuck in the open position so no boost can be built to protect the turbos. If I remember the usual codes are something like 30ff or 30fe. If you have Carly or someone does close by they could scan and check for you.
SteveSmith
No Boost - Help!!
Post by SteveSmith » Thu May 17, 2018 7:52 pm
Hi all,
All sorted now. It was the boost pipe from turbo to intercooler that had completely filed. Plastic boost pipes!? Apparently all manufacturers use these now as silicone hoses perish.
BMW really weren’t great to deal with. All dealerships are absolutely stacked with recalls!!
