Due to an utter moron in a tractor going down a flooded road at 35 to 40mph my Z4 got covered in muddy water. I've cleaned most of the car up, which has meant things like taking the wing mirrors apart to get full movement back, taking the door to bits, etc. However the engine is still getting way too hot - it's struggling to keep the oil temps under 130C under any kind of non-cruising condition. There's no mud on the front of the radiator or IC anymore so I'm assuming that it's coated with dry mud on the inside of the fins.
Are the radiator & IC up to being directly pressure washed or is this a steam cleaner job?
Cleaning the radiator & IC after a mud bath
- techathy
Current: '09 Lotus Evora Launch Edition
Previous: '13 BMW 120dx, '15 BMW z4 35iS
- Smartbear
I would try a normal hosepipe before the jet washer option just in case it started bending the fins over.techathy wrote: ↑Sun Apr 08, 2018 8:15 pm Due to an utter moron in a tractor going down a flooded road at 35 to 40mph my Z4 got covered in muddy water. I've cleaned most of the car up, which has meant things like taking the wing mirrors apart to get full movement back, taking the door to bits, etc. However the engine is still getting way too hot - it's struggling to keep the oil temps under 130C under any kind of non-cruising condition. There's no mud on the front of the radiator or IC anymore so I'm assuming that it's coated with dry mud on the inside of the fins.
e85 3.0si sold
- techathy
Already hose piped, that helped a lot, cruising oil temps end are now stable at 110C, but it's still getting too hot.
Should also mention I tried a hand pump spray but that doesn't seem to have enough volume behind it so water doesn't end up blow all the way through, it just trickle out.
On the bright side, at least you had the roof up!!
Mark
Plymouth
E89
35i
Carmine Red
Black leather
Plymouth
E89
35i
Carmine Red
Black leather
- MrPT
Is your radiator fan working?
2006 Z4 2.5si: gone
2006 Z4 2.5si: gone
- techathy
mcbutler, I'm glad I decided to put the roof up before going for a little wading session. I don't even want to think about the consequences of not having done that.
MrPT, Definitely working just doesn't seem to have much relationship to the oil temps. I'm starting to think that actually the radiator maybe okay but the oil cooler is actually the problem.
