So basically sealant around all the holes as well as the perimeter of the light itself should do the job
Water Ingress...
Water Ingress...
Silver E89 Z4 sDrive20i M Sport
Water Ingress...
If the seals are fitted correctly, they don't (shouldn't) leak.
- R60BBA
Water Ingress...
Agreed.
Sometimes wateringress in tail lights or headlights can be due to the car having had previous bodywork before, and seals not installed correctly thereafter.
Check the rear to see if you can see any signs of repair work
Current: 2002 E46 M3
Current: 2004 R53 Cooper S
Current: 2005 997 Carrera S
Gone: 1998 E31 840Ci Sport
Gone: 2007 Z4 E86 3.0Si Sport
Gone: 2015 F21 116d M Sport
Water Ingress...
No signs of repair work, weather permitting I plan to strip the lights off this weekend and just want to be sure when I put them back in I am putting sealant back in the right place, I didnt plan on replacing the seals but using sealant as an additional barrier as the water is getting in somewhere. Sounds like new sealant around the light perimeter and then double checking the seals are installed correctly should be my approach.
Water Ingress...
Spent 2 hours this morning removing my left rear light, unfortunately at 2.02 on the video, https://www.youtube.com/watch?v=wHJa6z6e-a0 in my 2012 Z4 its designed differently and doesn't slid out, so an adjustable spanner and some swearing was required to get the screw off the light to get it out. Now that its out, there was a lot of dirt and crude around the seals as shown.
I have now cleaned all the dirt and crude away and stopped for lunch. My issue is do I just put it back cleaned up, the seals themselves look fine, has all the dirt and crude stopped the seals working correctly and sending the water elsewhere, into the boot rather than draining away as it should? Or do I put sealant around the perimeter.
Having removed the lights I noticed this, I assume these are two drainage holes and is where the water is meant to drain out, the plastic isn't solid in place I am tempted to put sealant below the plastic to keep it in place, I wonder if the plastic actually covers the holes meaning it doesn't drain as it should.
Double checking the tissues I had in the boot, the water seems to be mainly coming straight in from the back, I have removed all the clips but I cant get this bit off.
It seems to be held on by these screws but despite trying to get them off they won't budge, is it a special type of part to get that off?
- Mikopop
Water Ingress...
Hi Amg01
Quickie for you, I also have noticed a small amount of water inside the o/s rear light.
How difficult is the light removal??
Is it a few screws or something altogether more complicated.
Want to try and remove, dry out/empty the water and replace before I spring £130 for a new light.
2009 E89 2.3 silver
Water Ingress...
https://www.youtube.com/watch?v=wHJa6z6e-a0&t=8s
Take lamp apart by easy off the clips, dry out, then i sealed with Evostick spray glue, Reclip then another coat of glue around the joint and refit. Some folks used silicone sealant, but i found it would not stick to the plastic well long term and would part with time allowing water back in. Even new lamps leak because they have the same flaw.
- Mikopop
Water Ingress...
Hi Flybobbie
I appreciate the good info, if we are glueing and or siliconing in does it make it difficult to change bulbs??
Many thanks
Many thanks
2009 E89 2.3 silver
Water Ingress...
No, but you are not sticking the unit to the car. The bulbs can be replaced with the unit in place. The turn leds are not replaceable.
- Mikopop
