rough idle when cold
Nick9one1
Post by Nick9one1 » Mon Jan 22, 2018 8:58 am
Scooba_Steve wrote: Sun Jan 21, 2018 9:07 pm If you got from a Trade seller and only got the car in December then contact them immediately and explain the issue (you have significant rights in the first 30 days), they will be responsible for a FOC repair unless they can prove the fault was not there at the time of sale.
Thanks, I'm aware of the consumer rights act but it was a private sale.
Z4 35i Space Gray, Red Leather
Stepped Intercooler
De-Cat Downpipes
HKS SSQV
MHD 98RON Stage 2+
395 BHP :driving:
Nick9one1
Post by Nick9one1 » Mon Jan 22, 2018 9:17 am
mcbutler wrote: Sun Jan 21, 2018 7:30 pm Tell me more about this walnut valve cleaning kit please???
As Rob said you probably wont need this.. because the 23i has fuel injected in the inlet, it keeps the valves and ports clean.
going a bit off topic here. But in case anyone else is interested its relatively straightforward...
You need, an air compressor, shot blasting gun, some ground walnut, a vacuum and a walnut blasting vacuum attachment.
essentially you blast walnut into the valve cleaning it, while the adapter helps vacuum away the used walnut/carbon.
The only part I didn't have was the blasting vacuum attachment. They're £60+ so I 3D printed one for a couple of quid.
Full DIY guide for the 335i
Stepped Intercooler
De-Cat Downpipes
HKS SSQV
MHD 98RON Stage 2+
395 BHP :driving:
mcbutler
Post by mcbutler » Mon Jan 22, 2018 10:25 am
Nick9one1 wrote: Mon Jan 22, 2018 9:17 am
Thanks for that, very interesting. 23i is direct injection, pretty sure about that..
Mark
Plymouth
E89
35i
Carmine Red
Black leather
ph001
Post by ph001 » Mon Jan 22, 2018 12:14 pm
£102 is a great price for an injector from Sopers. Last time I looked, they were nearer £200 ech. Sounds like you have illiminated coil packs so injectors will certainly be next on the suspect list.
Smartbear
Post by Smartbear » Mon Jan 22, 2018 12:17 pm
mcbutler wrote: Mon Jan 22, 2018 10:25 am
Nope, 23i isn't direct injection-the n54 and n20 engines are but the m54 /n52 engines are not :thumbsup:
e85 3.0si sold
Nick9one1
Post by Nick9one1 » Mon Jan 22, 2018 12:44 pm
Smartbear wrote: Mon Jan 22, 2018 12:17 pm Nope, 23i isn't direct injection-the n54 and n20 engines are but the m54 /n52 engines are not :thumbsup:
Robs correct, just checked realoem. It has no HPFP and standard injectors.
23i IS NOT direct injection
28i IS direct injection
http://www.realoem.com/bmw/enUS/showparts?id=LM32-EUR-05-2010-E89-BMW-Z4_23i&diagId=13_1186
Stepped Intercooler
De-Cat Downpipes
HKS SSQV
MHD 98RON Stage 2+
395 BHP :driving:
Nick9one1
Post by Nick9one1 » Mon Jan 22, 2018 12:48 pm
ph001 wrote: Mon Jan 22, 2018 12:14 pm £102 is a great price for an injector from Sopers. Last time I looked, they were nearer £200 ech. Sounds like you have illiminated coil packs so injectors will certainly be next on the suspect list.
Yeah I was pleasantly surprised!
I'm going to swap all of bank 1 (cylinders 1,2,3), to begin with.
Stepped Intercooler
De-Cat Downpipes
HKS SSQV
MHD 98RON Stage 2+
395 BHP :driving:
ph001
Post by ph001 » Mon Jan 22, 2018 1:18 pm
Nick9one1 wrote: Mon Jan 22, 2018 12:48 pm
I suppose that will give you a good idea of what's involved but I bet you will need to swap the other bank as well within 12 months. If possible, it would be super to have a good DIY guide for the forum. I think the vast majority of people have had them done under warranty but you can be sure there are lots of cars falling out of warranty over the next few years so I think a good guide would be very valuable.
Nick9one1
Post by Nick9one1 » Mon Jan 22, 2018 6:54 pm
Yeah I'm pretty sure I'll have to change the remaining three before long.
Stepped Intercooler
De-Cat Downpipes
HKS SSQV
MHD 98RON Stage 2+
395 BHP :driving:
mcbutler
Post by mcbutler » Mon Jan 22, 2018 10:46 pm
Nick9one1 wrote: Mon Jan 22, 2018 12:44 pm
OK, in that case where are the 23i injectors mounted, in realoem I cannot see any mount or hole on the inlet manifold?? Do they go into the port before the inlet valve? i.e. mounted on the head?
Mark
Plymouth
E89
35i
Carmine Red
Black leather
Smartbear
Post by Smartbear » Mon Jan 22, 2018 11:23 pm
mcbutler wrote: Mon Jan 22, 2018 10:46 pm
Yes, they inject into the inlet port (keeping the inlet valves clean) but not directly into the combustion chamber :)
e85 3.0si sold
Nick9one1
Post by Nick9one1 » Mon Feb 12, 2018 6:38 pm
I've got a feeling the new injectors will never come into stock.
The availability date has been pushed back three times now.
From what I've been told,
13-53-8-648-937 (£102) is used by dealers when repairing under warranty (so they are less out of pocket until the reimbursement comes back from BMW)
13-53-8-616-079 (£240) is what the dealer wants to sell you
They are exactly the same injector.
Stepped Intercooler
De-Cat Downpipes
HKS SSQV
MHD 98RON Stage 2+
395 BHP :driving:
Smartbear
Post by Smartbear » Mon Feb 12, 2018 6:54 pm
Nick9one1 wrote: Mon Feb 12, 2018 6:38 pm I've got a feeling the new injectors will never come into stock.
I wonder why they’ve given them different part numbers if they really are the same part? It makes no sense :?
e85 3.0si sold
Nick9one1
Post by Nick9one1 » Tue Feb 13, 2018 1:00 pm
The code printed on the injector is 13-537-585-261 12 no matter which part number you order.
13-53-8-648-937
13-53-8-616-079
This article gives a bit more information..
The key bit being
There is no difference between 13538648937 and 13538616079 in terms of quality. The injectors are identical in every measurable way. Originally, the 937 injector was the improved version as part of the TSB but now both part numbers have the improved version. Why does the 937 injector cost less? It costs less because it's more of the true cost of the part. This reduces the cost the dealerships need to inherit for warranty work on a common failure item until reimbursement from BMW. The separate numbers are also established to artificially decrease the reported failure rate. One part is to handle the warranty and recall claims (not reported) and the other is strictly for retail and regular service work (more profit).
Stepped Intercooler
De-Cat Downpipes
HKS SSQV
MHD 98RON Stage 2+
395 BHP :driving:
Gaffa22
Post by Gaffa22 » Tue Feb 13, 2018 1:45 pm
Nick I don't think you can mix index 12 with index 7 so you might have to get all 6
the injectors (pt no 648937) you have been quoted £102 are index 12 and are slightly different to the pt no 616079
2010 E89 35i DCT
2017 Honda CBR1000RR fireblade
2016 Honda VFR1200F
