Rear tailight cluster out and fuse 6 keeps blowing
merlintilly
Post by merlintilly » Tue Jan 09, 2018 8:52 pm
Hi
The rear taillights are out started with N/S now OS as well and now fuse 6 keeps blowing when the ignition is turned on. Sounds like a direct short of the wiring harness. Is there a joint in it between front and rear and if so where is joint so I can diagnose where the fault is located? Or any other suggestions?
flybobbie
Post by flybobbie » Wed Jan 10, 2018 9:56 am
https://drive.google.com/file/d/0BxW-0N ... 9KM1k/view
wiring diagrams towards the end of document.
Leafywalton
Post by Leafywalton » Sat Mar 31, 2018 1:26 pm
It’s probably water in the cluster from poorly designed seals. I drilled small drain holes at the bottom of the cluster and half a cupful of water drained out. Problem fixed once they dried out! See my post and photos.
Z4M-2006
Post by Z4M-2006 » Sat Mar 31, 2018 1:29 pm
Wiring harness and plug into rear lights melts and shorts.
Common problem on all BMW's,you can buy repair kits from BMW
