Roof problem
FLATSPOT
Roof problem
Post by FLATSPOT » Mon Dec 18, 2017 8:27 pm
Hi I have just purchased a 2009 3.0 sdrive and I'm not sure if there's a problem with the roof when I put the roof up the back half of the roof seem slam into place it does not just drop it seems to lower its self down ok but it seems to land with a bit of a heavy clunk is this normal or do I have a problem any advice would be appreciated
dario
Roof problem
Post by dario » Mon Dec 18, 2017 8:32 pm
Mine on occasions does a heavier than i'd like it clunk, but its being doing it for a few years. what not post a video of it so it can be assessed more accurately?
35i - DCT - Most of the toys - Smart top roof module - GLF.
Lazza
Roof problem
Post by Lazza » Tue Dec 19, 2017 1:55 pm
Mine lands with a bit of a thump too. Having only owned manual roof convertibles (Mazda MX5) before, it was a surprise to me but I'm sure it's normal.
Z4 S-Drive 35i
Audi TT S-line
Mazda MX5 Mk2.5 (for sale)
Wokingham Berkshire
Bertz4
Roof problem
Post by Bertz4 » Tue Dec 19, 2017 2:31 pm
Mine also bangs down onto the screen top, probably due to the weight of the roof header overcentering. I just catch it with my hand to stop the bang.
Current: 2005 Z4 3.0i Sterling grey, red leather, 108's.
Previous: 1991 TVR S3 2.9 V6
mcbutler
Roof problem
Post by mcbutler » Fri Dec 22, 2017 6:29 pm
Take a couple of hours to lubricate every pivot/joint/hinge in the entire roof mechanism.
Do it first with a PTFE spray (B&Q) and a week later with a white lithium spray grease (again B&Q).
This reduces the friction load in the mechanism hence operating pressures/heat in the pump decrease. Roof operating process becomes smoother/quieter and faster..
flybobbie
Roof problem
Post by flybobbie » Fri Dec 22, 2017 7:38 pm
My roof always pauses for a fraction of a second before it shuts, but my colleagues car, which she always had problems with the roof, would crash down. Hydraulic cylinders can be designed so that they cushion on the last part of the stroke, don't know if that is so with these, but the roof cylinders on my car exhibit such an action.
Or my roof hydraulics could be down on pressure so it falling under gravity and last moment pressure builds to shut.
Maniac
Roof problem
Post by Maniac » Fri Dec 22, 2017 8:04 pm
Mine used to do this.
Lubrication caused a very jerky mechanism so I can’t recommend that.
There are two sets of rubber stops for the rear clamshell which can be adjusted up to help stop the slam.
Yours may have moved down as the design is poor.
Find them, put some sticky felt on them, sticky side against the rubber stop and this should help soften the impact.
It’s been like that for years on mine (extra felt on the rubber stops) and is fine.
flybobbie
Roof problem
Post by flybobbie » Fri Dec 22, 2017 8:08 pm
I miss read the original post, yes my rear slams down firm but not crash.
FLATSPOT
Roof problem
Post by FLATSPOT » Tue Dec 26, 2017 9:47 am
Thanks to all of you for your advice I will have a look at the roof when I'm off work over Christmas
FLATSPOT
Roof problem
Post by FLATSPOT » Wed Dec 27, 2017 1:49 pm
does anybody no how to check the roof hydraulic fluid level
flybobbie
Roof problem
Post by flybobbie » Wed Dec 27, 2017 2:05 pm
Just lift up the cover you will see the pump has a clear reservoir. It would appear that about half full is the norm, unless someone else can advise otherwise.
