Rough cold start with 35is
Ozie
Post by Ozie » Wed Apr 12, 2017 6:10 pm
Does anyone know what's the problem in next case?
After cold starts in the morning whole car shakes a bit and the engine isn't running smooth. Sometimes there is misfire (once from 3 cyl, then 1 & 3 cyl and this morning 1 cyl). After shutdown and restart everything is fine except smoke/vapour from exhaust.
Here's few screenshots from Carly this morning.
Image Image Image Image
Z4M-2006
Post by Z4M-2006 » Wed Apr 12, 2017 6:45 pm
Probably injectors....
Very common fail from cold start
Chris_D
Post by Chris_D » Wed Apr 12, 2017 7:06 pm
My e36 coupe (m52tu 25) did this sporadically from 40k miles to 261k miles... I didnt do anything to address it.
Image Image Image
Now: E85 3.0iSE roadster (03) 'Bruiser'. E93 320d M-Sport Cabrio (11) 'Bob'.
Past: E36 323i (96) 'Benny' 18yrs/260k RIP. E46 M3coupe (03) 'Pongo' RIP. Ariel Atom 2(shared).
R.E92
Post by R.E92 » Wed Apr 12, 2017 9:32 pm
That'll be fuel coming out of the exhaust. At least one injector is sticking open.
Best course of action is to replace all six. The latest revision of the injectors seems much more reliable.
Without warranty they are expensive. Proper new OEM injectors are £200 each, don't waste your time with reconditioned or old stock. It's a viable DIY job buy you need to use INPA or ISTA to register the new injector flow values so that can be a PITA if you aren't tech savvy.
If you have a warranty take it to BMW and they will have it done in a week. Just make sure you chat with the tech who is doing the work and remind him to fit the brackets/couplers to each injector as dealerships have been known to miss them out causing all sorts of odd issues (happened on my own car even after I asked them to double check after reading forum horror stories).
The injector has been dousing the cylinder with fuel causing failure to ignite thus a misfire The fuel will just wash through the exhaust system which could screw your cats up.
Part number for the latest index 12 injector is "13538616079"
Ozie
Post by Ozie » Thu Apr 13, 2017 5:38 am
Thanks. Already got price replacing all six injectors for 1860 € / £1580 and part number matches.
R.E92
Post by R.E92 » Thu Apr 13, 2017 9:18 am
That's a reasonable price. Just make sure they know about the couplers otherwise there is potential for engine head damage.
Ozie
Post by Ozie » Wed May 03, 2017 8:10 pm
Got injectors replaced and solved the problem of shaking.
Still there's problems in cold start. After hitting start button, rpm goes 2-3k and then as low as 500 before leveling to 1k and then 600. Sometimes there might be problems with some cylinders starting.
After restarting everything is fine, but again some fuel from exhaust.
Z4M-2006
Post by Z4M-2006 » Wed May 03, 2017 8:22 pm
Did you replace all the injectors for new and code them ?
Ozie
Post by Ozie » Wed May 03, 2017 9:29 pm
Yep.
Z4M-2006
Post by Z4M-2006 » Thu May 04, 2017 6:36 am
Coils?
The fuel monitoring system on the N54 seems very reliable ..
Injectors, coils and hpfp are your main gripes..
You need some diag kit hooked up to check live readings on cold start and see if there is anything showing
Ozie
Post by Ozie » Thu May 18, 2017 9:18 pm
https://1drv.ms/v/s!AnEbnHnovghamrc4Xt_KtMkqvCBG2A
Here's video of cold start few days ago. All cylinders ok this time.
Maniac
Post by Maniac » Fri May 19, 2017 7:32 pm
The long crank alone makes me think HPFP. Had exactly the same, got it replaced, been one crank to start since. Flawless.
jimbo1958
Post by jimbo1958 » Fri May 19, 2017 9:30 pm
Mine was a £2800 job but covered under Warranty. They had to replace a module as well though.
"There are fewer more distressing sights than that,Of an Englishman in a baseball cap
And we'll die in the class we were born,Well that's a class of our own my love."
Ozie
Post by Ozie » Wed Nov 01, 2017 9:46 am
Again with this problem. Yesterday when I was going on a highway and gave some gas I got half engine warning light. After restarting engine all was fine, but same problems and warning light also after accelerating bit harder.
Also got few misfires earlier..
Here are error codes:
Image Image
Injectors were replaced 6 months ago. HPFP?
Z4M-2006
Post by Z4M-2006 » Wed Nov 01, 2017 10:09 am
Yea,
Classic HPFP problem
Who is online
Users browsing this forum: No registered users and 6 guests
