FOR SALE F/S Jump Starter Battery Pack (1500A Peak 20000mAh Battery)
You must have a post count >25 to post adverts in here (private sales only, no traders)
ronk
Post by ronk » Wed Apr 15, 2020 11:36 am
kis wrote: Wed Apr 15, 2020 9:36 am I've invested in a ctek recently, using a 30 meter extension it can easily reach all our cars if they are on the drive. (the extension reel and ctek can be popped through the window, then wound up till it's just a crack). So just a matter of rotating them on and off the drive. If you start the charge in the morning, it's normally done by the evening so you don't have to leave it overnight.
Ironically works for all cars but the Zed! No folding rear seats! :rofl:
Unfortunately the fella has not got a drive - the 240v cable would have to go over a public footpath.
kis
Post by kis » Wed Apr 15, 2020 12:50 pm
Might have an issue with the solar then, as said it only maintains, doesn't really charge.
So you'd have to ensure the battery is fully topped up first. Before putting it on a solar maintainer.
My E85 Z4 3.0i SMG
1 Series - E87
4 Series - F36, F82 M4
5 Series - E34 (x2), E39
7 Series - E32
X5 - E53, E70
X6 - E71
ronk
Post by ronk » Wed Apr 15, 2020 1:28 pm
kis wrote: Wed Apr 15, 2020 12:50 pm Might have an issue with the solar then, as said it only maintains, doesn't really charge.
Yes - I did the volts/watts conversion and it’s only circa 0.2 amps - and only during daylight of course! (About 12hours ?)
It should replace the normal loss tho,
Either way - a new battery @ £300 V a new DPF @ £1300 - I know which way I’d go and it wouldn’t be starting the car for 15mins a week,
