SOLD E86 Z4MC Silver Grey / Black 2007 3.2l S54 - 6 Speed Manual
My 2007 Z4 M Coupe E86, Silver Grey, Black M leather interior and leather carbon effect dash, it’s a very high spec car, I have enjoyed my ownership but have a kid on the way so need something more practical.
Located in Solihull, West Midlands, B92, private message me if interested - £13,100.
It’s in excellent condition inside and out, even the drivers seat bolster has very little wear, and with the personal plate (MRZ 8604) it’s ageless.
Car has approx 139,000 miles but you wouldn’t know it, money has been no object, with an impeccable service history and preventative maintenance record.
It has a full service history at BMW and specialists (better than required), and all the important maintenance work over the normal service requirements, especially big end shells and the ARP bolt upgrade, and vanos rebuild and upgrade (all receipted).
The bootlid was repaired (a common corrosion issue) by BMW right near the end of the warranty last year (most of these are now out of warranty), the front bumper has been resprayed to a very high standard and looks fantastic.
Spec Includes;
Satellite Navigation (2018 maps)
10 Speaker Sound System, with CD Changer and Aux port
Heated Leather in Black
Electric Memory seats
Auto Headlights, Xenon self levelling
Auto wipers
Extended Storage
Tyre Pressure Warning
Climate Control
Cruise Control
(It has Bluetooth, but I never got it to work with my phone, comes with replacement Bluetooth module)
2 working cup holders..
MOT until Sept 2021.
Service History/Maintenance;
6.3.07 - Pre Delivery Check- Specialist Cars Stevenage BMW
1,150 - Specialist Cars Stevenage BMW- Oil service
11,421- Chandlers BMW- Oil & brake fluid Service
23,828- Chandlers BMW- Inspection 1
36,924- Chandlers BMW- Oil & Brake Fluid Service
49,718- Chandlers BMW- Inspection 2
62,302- Darjac Racing-Oil & brake fluid Service
68,960- Darjac Racing- Oil Service
Wheels Refurbished
73,640- Darjac Racing- Inspection 1 (Including valve clearances, new gearbox and diff fluids) Besian Systems Vanos Seal Kit & BMW Solenoid Plate fitted
74,141- 4 Wheel Alignment
83,936- MSM Independent BMW Specialists- Oil Service, New Discs and Pads
90,688- MVT Poole BMW Specialists- Inspection 2 (including gearbox and diff fluids, valve clearances and new shells with ARP bolts)
103,999 - Allen PMW BMW specialist - Oil service, wheel alignment, replacement pcd sensor.
28th Feb - Allen PMW - Brake fluid service and bumper alignment.
121,000 - 10/03/20 Hughes Brothers - Inspection 1 brake fluid, pollen filter, oil filter
137,970 - 17/06/21 The Works Mini & BMW Specialist - Inspection 2 air filter, gearbox oil, dif oil, rocker cover gasket, micro filter, spark plugs, oil filter
27/07/21 - brake disc backing plates replaced N/S & O/S front, replaced O/S/F window regulator, replaced noisy heater blower assembly bearings, respray front bumper and replacement of O/S/F wheel arch liner and undertray.
Selling with number plate.
All tyres replaced recently with Toyo Proxes.
All books and receipts + 2 keys.
Spec Includes;
Auto wipers
Extended Storage
Climate Control
Cruise Control
Wheels Refurbished
Last edited by chriswats2000 on Sat Sep 04, 2021 7:09 pm, edited 5 times in total.
- Wondermike
- Moderator
£13,750 E86 Z4MC Silver Grey / Black 2007 3.2l S54 - 6 Speed Manual
Price reduced to £13,750
Last edited by chriswats2000 on Tue Aug 10, 2021 10:17 pm, edited 1 time in total.
- Wondermike
- Moderator
Looks like a nice car!
Sepang Coupe
Imola Roadster - For sale
Interlagos Coupe - For sale
Previous:
Stratus Grey Coupe
Titan Silver 3.0 Roadster
Carbon Black Coupe
Silver Grey MR
Silver Grey 3.0si Roadster
Maldives Blue 2.5
Sterling Silver 3.0 - twice
Previous:
Stratus Grey Coupe
Carbon Black Coupe
Silver Grey MR
Maldives Blue 2.5
I can't believe I even looked at webuyanycar as an option....
- Screenshot_20210806-195555.png (139.22 KiB) Viewed 1744 times
Reduced to £13,100
OnlineMartyn
£13,100 E86 Z4MC Silver Grey / Black 2007 3.2l S54 - 6 Speed Manual
Hi OP..
I’m a bit surprised she hasn’t sold in the month it’s been for sale, on here
Interesting to read in your Service History notes, that she had:
Vanos seal kit, fitted at circa 73k;
Brake Discs etc, last changed at circa 83k & shes now sat on circa 139k.
A friend & myself, have been on the look-out for a potential joint track toy & this might fit the bill.
Could I therefore please ask: how the Vanos is performing currently & your estimated life left in the front & rear brake discs & pads? Purely, as both the above subjects - can be a hefty repair / replacement bill
Of worthy note: I see she’s had circa 13 oil changes etc
Hi Wooly,woolybear wrote: ↑Fri Sep 03, 2021 10:06 am Hi OP..
Something I probably should have mentioned is that I've recently spent £3k on the inspection 2 plus additional bits that I had done but at the last service, although there was no Vanos fault code on the ECU, they ran what they called a 'Vanos tolerance test' which failed at very low revs. There is a slight stutter which may be caused by the Vanos which is around 1,000-1,500 RPM - it pulls perfectly once beyond that. They quoted £1100 for parts and labour to replace the Vanos.
Regarding the discs, I think they were replaced at 110k miles - I'll have a look through all the paperwork and will let you know. I can take some photos also if that's any good to you?
Drop me a message if you're interested in seeing it in person.
Cheers,
Chris
Chris..chriswats2000 wrote: ↑Fri Sep 03, 2021 9:26 pmHi Wooly,woolybear wrote: ↑Fri Sep 03, 2021 10:06 am Hi OP..
Cheers,
Chris
Sadly, if we are facing a new Vanos bill - for circa £1,100 from the outset, it’s a no-go sorry.
On a mildly more positive note:
Personally, I think I may well of been singing the car’s praises & displaying your recent Insp2 invoice for circa £3,000 - on here for all to clearly see, exactly what you’ve recently invested in the car.
..Equally, if there’s an invoice for new brake discs & pads, you mention we’re fitted at circa 110,000 miles - I’d add that on here also, to reassure other interested parties, that it won’t need the expensive new discs & pads - in short due course..
