2003 BMW Z4 3.0i Manual - Titanium Silver and Black Leather, high spec. including Carver stereo, SatNav, Xenon headlights, cup holders and heated seats. around 145k miles. pictures to follow at the weekend...
Car is in Romsey, Hampshire
I bought the car September 2016, she has 3 former keepers. Externally, she is showing her age a little, but still solid and sound. Minor (rust?) blisters in rear wings, and light scratches on one wheel arch. I have tried to fix things properly in my ownership, so quite a lot has been spent on her, as I had intended to keep her for many years, but as I'm learning nothing is certain in life
Service history
Previous owners
09/08/06 - New wiper blades
03/07/07 - MoT
11/01/08 - BMW Inspection II, replaced all ignition coils
05/07/08 - MoT & new rear coil springs
03/08/09 - MoT
14/07/10 - MoT
24/07/08 - New window lifter, drive & switch
01/08/11 - MoT
14/02/12 - Full service & front discs & pads
24/07/12 - MoT & replaced OSF suspension arm & bush
31/07/13 - MoT and replaced front to rear brake lines
22/08/13 - New airbag ECU
28/08/13 - Full service
15/04/14 - New starter motor
22/04/14 - New alternator
08/08/14 - Annual Service & MoT. Lower arm, and lower rear bush replaced.
11/08/15 - Lube service & MoT
In my ownership
Fitted a set of refurbed 108's (courtesy of Mr Wilkes)
26/11/16 - 2 x Ignition coils
08/12/16 - New Powerflex rear trailing arm bushes, new DISA valve, rear suspension spring, radiator hose & temperature sensor.
21/04/17 - New Brembo rear discs and pads
30/08/17 - Bilstein B4's fitted, with new top mounts hardware. New handbrake fitted,
03/09/17 - Expansion tank replaced
20/03/19 - Ignition coils replaced x 4
14/02/19 - Inspection II service, new oil filter housing gasket
06/02/19 - MoT, replace OSF lower suspension arm, rear bush & OSF drop link
25/02/19 - replaced rear/main differential mounting bush
28/02/19 - Cooling fan replaced
CCV and rocker cover gasket recently
New Varta battery recently
New Rainsport 3's on the front
Good Rainsport 3's on the rear
Roof motor relocated
Known faults
Central locking doesn't work. I replaced the relays on the GM5 to n avail. I understand that the GM5 needs replacing
Pop up screen can be temperamental.
FOR SALE 2003 BMW Z4 3.0i Manual - Titanium Silver and Black Leather - £3k
2003 E85 3.0i, 144000 miles and counting...
