2003 BMW Z4 2.5i Convertible Manual Titan Silver Leather
Reluctantly for sale, my BMW Z4. I bought it with the intention to bring it up to perfect standard, then fit a supercharger and use it as my weekend fun car. Unfortunately a new job with a commute and no carport to work under means that I must cut this short. There is a short summary and then below it a full account of the car.
Please note I am out of the country until 10th October.
Google Gallery - extra high resolution photos
https://photos.app.goo.gl/ozQVUNAy76Hif7Zv9
The Facts
142,000 Miles
July 2019 MOT
MOT history shows no horrors
5 Previous Owners
Fantastic condition for age
2.5 straight six M54 engine, powerful and silky smooth, spins like a turbine
Yokohama front, Michelin rear tyres, all replaced this year and in good order
Oil service just completed
£2500 of service receipts including valve cover gasket, VANOS rebuild, aux belts, suspension control arms etc
Viewing in Wellington, Somerset, or Newport, South Wales
My number 07777 621 564
I am not accepting offers on the car as I think it´s very keenly priced for the condition and the work done as detailed below
In detail
I bought the car from a gentleman in Somerset who had owned the car for the past 4 years (if memory serves me correctly). It has only 5 previous owners and has been looked after with documentation to prove so. I have set out the service records and receipts below (totalling £2500, which is a fraction of what has actually been spent, but I don't have every invoice).
When I got the car it was obviously well cared for but had room for improvement.
I have changed the oil, given it a full check over, and spent at least 70 hours tending to all the common maintenance jobs required on Z4s of this age.
One of the main issues with the M54 engine is the VANOS system. This variable valve timing system is one of the reasons that the engine is so powerful and economical, but the seals inside degrade over time and prevent the system from working properly. If you have driven one of these cars and felt like it was a bit "flat" or underwhelming until higher in the rev range, the VANOS is the culprit.
Unfortunately, it is a very labour intensive job and most garages, if they are even inclined to take it on, will charge between £600-£1000 to overhaul the VANOS. I have done this job on the car and it really transformed the drive. I used upgraded teflon seals from X8R meaning they will never need to be done again for the life of the car.
Another common fault on the M54 is the valve cover gasket. It hardens over time and leaks oil onto the manifolds, causing a stink, and loss of crankcase vacuum, which also causes hesitation and excessive oil consumption. This again is a labour intensive job that I have completed using ELRING quality gaskets.
The DISA (manifold runner diverter flap) can fail on these, I removed the valve, checked it for correct function and resealed it to the inlet manifold.
The PCV (positive crank ventilation system) has been checked for function and any split pipes, no problems, fine and working well.
I've done an oil and filter change, air filter, checked the spark plugs which are NGK iridium with a 60k service interval. I also replaced both aux belts as one was looking a little tired. The expansion tank has been replaced by the previous owner and I refreshed the o-ring seals due to a slight weep. Coolant has also been changed.
The wheels have been refurbished in gloss black as they were looking a little tired. The whole car has been machine polished and sealed with a 12 month synthetic paint sealant. The roof has been cleaned and sealed with Autoglym products. It looks AMAZING in my opinion.
I've changed the front pads for new Pagid as I didn't like the mintex ones on there. I have the matching Pagid rear pads but haven't fitted them yet.
The previous owner spent a lot on suspension arms, ARB links, grooved discs all round, clear brake light, angel eyes, red rear light clusters, I have detailed this in the table below. The throttle body and air mass sensor have been replaced and the software updated.
Being very critical, the front bumper has some hazing to the clearcoat and the lower grille is aluminium mesh rather than the original plastic insert. There are a few small chips to the passenger side rear wing. This in no way detracts from the appeal of the car, I think you will agree.
The car drives extremely well and sounds delightful through the rev range. A paper S2000 filter has been fitted which does make a noticeable improvement to throttle response, though it can be removed and reverted to original airbox with a new Mann filter if preferred.
It has a JVC stereo fitted with bluetooth and AUX in. It sounds great so I think the speakers may have been upgraded but I haven´t checked.
Overall it´s an absolute joy to drive, no issues, looks fantastic, I am confident it´s better than the majority of Z4s out there. Viewing and test drive encouraged.
Date Item Detail Cost Hours Invoice?
9/18/2003 PDI ??
9/20/2006 Service 15820 miles ??
9/20/2006 Brake fluid 15820 Miles ??
12/21/2009 Insp 1 32108 miles ??
7/15/2011 Service 48372 miles ??
3/31/2015 Throttle body Diagnose faulty throttle body, replace and update software £456.00 Y
6/4/2015 Suspension replacement OSF shock OSF Spring OSF Arb link £338.94 Y
3/14/2016 Insp 1 92384 Miles ??
7/25/2016 ARB links qty 2 £10.75 Y
8/1/2016 Front suspension arm L & R £90.98 Y
8/1/2016 Lollipop bush L & R ??
8/11/2016 Wheel Alignment 2 Yr Wheel Alignment Kwik Fit £129.95 Y
11/29/2016 Track Rod ends Qty 2 £29.30 Y
3/20/2017 Tyres Front Yokohama C Drive AC01 £144.00 Y
3/22/2017 Front wheel bearing Qty 2 £49.95 Y
4/18/2017 Steering rack gaiter Qty 1 £18.12 Y
4/25/2017 ARB links and bushes Starline / Lemforder Qty 2 ea £23.40 Y
5/22/2017 MAF Sensor Replace MAF sensor ACP brand £46.37 Y
6/16/2017 MOT and service Oil 5W40, oil filter, air filter, 6 NGK plugs £235.00 Y
1/2/2018 Tyres Rear Goodyear FIAS3 XL (Eagle F1) £160.00 Y
2/2/2018 Lube service Engine Oil 5/30 Synthetic, Castrol Syntrax diff oil 2L, Gear oil 75w80, wiper blades £226.17 Y
7/6/2018 MOT and ARB links MOT and ARB links £172.74 Y
8/28/2018 Double Vanos Rebuild double vanos with Teflon and Viton seals, new crush washer on pipe, clean solenoids X8R parts £79.99 Y
8/28/2018 Valve Cover Gasket Replace leaking VCG and bolt donuts ELRING parts ??
8/28/2018 Spark Plugs Inspect (condition good, NGK type installed 111k, replace after 60k) ??
8/28/2018 Oil Shell Helix AG Fully synth 5W-40 6.5L £59.98 Y
8/28/2018 Oil Filter MANN filter £4.75 Y
8/28/2018 Air Filter MANN Filter £8.01 Y
8/28/2018 Serpentine Belt 6PK Dayco Belt, tensioner and rollers good £14.29 Y
8/28/2018 V belt 4PK febi belt, tensioner good £12.32 Y
8/28/2018 DISA Valve Remove, clean, check function, reassemble with RTV on sealing face as o-ring compressed ??
8/28/2018 Intake Boot Repair cracked bellows, otherwise good ??
8/28/2018 Vacuum Lines Check condition of all vacuum lines ??
8/28/2018 Expansion tank Fix leak by installing two o-rings ??
8/28/2018 Undertrays Secure undertrays and repair cracks (some pieces still req'd) ??
8/28/2018 Pagid Front Pads PN 101110138 £19.25 Y
8/28/2018 Front brakes Deburr and clean discs, replace pads with Pagid standard, clean and grease slider pins, clean mounting faces ??
8/28/2018 Wheels Refurbish 4 wheels with optima gloss black, optima clearcoat ??
8/28/2018 Rear lights Red euro tint and new seals to fix leak £7.99 Y
8/28/2018 Wiper motor Disassemble and clean to fix wiper parking issue, clear drain channels ??
8/28/2018 Wipers New bluecol aero wipers £10.00 Y
8/28/2018 Cam angle sensor Clean exhaust cam angle sensor ??
8/29/2018 Optima Black Gloss Qty 4 £20.00 Y
8/29/2018 ECU adaptations Reset ECU to clear adaptation values ??
8/30/2018 Optima Clear Qty 3 £15.00 Y
9/3/2018 Rewire headlamps Rewire to correct hyper flash issue and connect angel eyes and LED park lamp ??
9/3/2018 Align lamps Repair mounting points and correctly align to body ??
9/3/2018 Clearcoat Qty 2 £12.00 Y
9/3/2018 Replace lower grille Fit aluminum expanded mesh ??
9/3/2018 Aluminium mesh Qty 1 £14.00 Y
9/3/2018 Center caps Black and white Qty 4 £5.99 Y
9/3/2018 Oil filter housing gasket Elring £8.02 Y
9/4/2018 Front badge Genuine BMW £5.99 Y
? M3 Style wheels ??
? Angel Eye LED Headlamps ??
? JVC stereo ??
? Drilled and grooved discs Front and Rear ??
? Meyle Expansion Tank ??
? Clear 3rd brake light ??
? Stubby Aerial ??
£2,429.25
SOLD 2003 BMW Z4 2.5i Convertible Manual Titan Silver Leather £2650
- 20180929_165720.jpg (273.96 KiB) Viewed 756 times
