SOLD 2013 Z4 35is - NOW GONE
2013 Z4 E89 35is – 17k miles, Possible PX for E85/6
Updated pics to show new mileage, oil temp after run out and idrive pics. Apologies for dust on screen, must have picked that up on the drive out yesterday with the top down iPhone camera has sharper eyes than mine
Next Z landed ..... Z3 3.0i Sport Roadster
Z4 35iS ..... Gone to a new home
Pre-weekend BUMP. Price reduced to £20,750
Brake fluid changed today in line with scheduled change and new shiny stainless steel 90mm exhaust tips fitted to replace the shabby un-polishable oem originals. They have been fitted with proper tightening collars to make any future changes to different size tips or to make any other adjustments easier
- Boyo
I like those exhaust tips - I have always been underwhelmed by the factory ones on my 35is. Could I ask where you got them and the tightening collars.
Current:
718 Cayman GTS 4.0 (PDK)
Previous:
G29 M40i - Thundernight
718 Cayman GTS 4.0 (Manual)
987 Boxster 2.7
E89 2.0i M Sport (Auto)
E89 2.0i M Sport (Manual)
718 Cayman GTS 2.5
E89 35is
E85 M Roadster
Previous:
987 Boxster 2.7
718 Cayman GTS 2.5
E89 35is
E85 M Roadster
I'm still interested if you'll reconsider.
07’ Z4 3.0si
Leicestershire
Leicestershire
Me too, they've bugged me for ages now, you just can't clean them up at all & I prefer the polished look. TRP Performance in Walsall Wood, my local independent that I use for the more menial servicing tasks. I took it there for the brake fluid change, but they also do tyres, custom exhausts, mapping and dyno sessions as well as servicing. I'm sure any custom exhaust specialist near you should be able to do the same and supply the collars too. They're 3.5" (89mm) diameter short trims, I really wanted the "Jet style" trim rather than the rolled edge but they only had those available in the longer length. They would have stuck out too far from the valance due to only being able to cut the existing pipe just in front of the exhaust flap bypass section. They offered to order the shorter version in but I wanted it doing there and then!
If I end up keeping the car I can always change them at a later date for a different size or style without all the hassle of grinding away welds and re-welding Hope this helps
Many thanks for your interest but considering what you paid for yours and your offer, it was quite a lot under where I'm looking to be. I'm in no rush, in fact I'll happily keep hold of her if she doesn't sell and maybe try again next year, or when and if the current climate ever improves.
I think the current price of £20,750 (Today's WBAC +12.15%) is fair considering it doesn't want for anything and is as low as I'll be going for the foreseeable.
GLWYS, I'm sure a buyer will come along soon, it's just a matter of waiting for the right one
- Boyo
Thanks that's really helpfuleff1guy wrote: ↑Wed Aug 15, 2018 9:18 pmMe too, they've bugged me for ages now, you just can't clean them up at all & I prefer the polished look. TRP Performance in Walsall Wood, my local independent that I use for the more menial servicing tasks. I took it there for the brake fluid change, but they also do tyres, custom exhausts, mapping and dyno sessions as well as servicing. I'm sure any custom exhaust specialist near you should be able to do the same and supply the collars too. They're 3.5" (89mm) diameter short trims, I really wanted the "Jet style" trim rather than the rolled edge but they only had those available in the longer length. They would have stuck out too far from the valance due to only being able to cut the existing pipe just in front of the exhaust flap bypass section. They offered to order the shorter version in but I wanted it doing there and then!
Current:
Previous:
987 Boxster 2.7
718 Cayman GTS 2.5
E89 35is
E85 M Roadster
Previous:
987 Boxster 2.7
718 Cayman GTS 2.5
E89 35is
E85 M Roadster
- Nictrix
They look cracking and fit really well.eff1guy wrote: ↑Wed Aug 15, 2018 9:18 pmMe too, they've bugged me for ages now, you just can't clean them up at all & I prefer the polished look. TRP Performance in Walsall Wood, my local independent that I use for the more menial servicing tasks. I took it there for the brake fluid change, but they also do tyres, custom exhausts, mapping and dyno sessions as well as servicing. I'm sure any custom exhaust specialist near you should be able to do the same and supply the collars too. They're 3.5" (89mm) diameter short trims, I really wanted the "Jet style" trim rather than the rolled edge but they only had those available in the longer length. They would have stuck out too far from the valance due to only being able to cut the existing pipe just in front of the exhaust flap bypass section. They offered to order the shorter version in but I wanted it doing there and then!
There was another car on here that had aftermarket tips fitted but it made it look like a wheel barrow as they stuck out too far.
Yeah I'm pleased with them. Went with the slash tip as well so the exhaust line follows the curve of the valance. The slash/angle isn't as pronounced as the originals which are really quite aggressively tapered in comparison. I had to go with what they'd got but didn't want a straight pipe as they tend to look a bit wheel barrow 'ish' as you say
2013 Z4 35is – 17k miles, Possible PX for E85/6/9
Sunny weekend BUMP
Hi, is Car still available?
W
W
Could come and view this weekend or next Thursday
If only my insurance company would play ball I would be interested!!
Toys: Z4 E89 35i in Blue / Ducati Multistrada 1260 DVT + love my watches
It is yes although I am currently in discussions with a forum member regarding a possible PX.
Have sent you a PM
