Torque setting for re-attaching rear shock?
Requests for how-to's go in here
RickZ4
Post by RickZ4 » Sun Oct 16, 2016 3:31 pm
Can anyone advise me what torque setting I should use when re-attaching my rear shock after replacing the broken coil spring..?
07 2.5i Sport with lid and Monkey tips
Online
GuidoK
Post by GuidoK » Sun Oct 16, 2016 4:47 pm
100Nm.
But you have to tension it at normal driving position.
torque it down with the wheels down / in full droop will damage the shock rubber bushing.
So the wheels have to be sitting on the ground or the rear suspension trailing arm has to be jacked up.
RickZ4
Post by RickZ4 » Sun Oct 16, 2016 5:28 pm
GuidoK wrote:100Nm.
Thanks :thumbsup: Easier on a ramp, I guess...
Online
GuidoK
Post by GuidoK » Sun Oct 16, 2016 7:19 pm
On a 4 post ramp it's easy yes. (if you have a pit its also easy)
With 2 post ramp you need a transmission jack to jack up the rear trailing arm to get it somewhere in the driving position.
Who is online
Users browsing this forum: No registered users and 1 guest
