HOWTO: Fix wiper resting point issues
Rorybeanbutler
Re: HOWTO: Fix wiper resting point issues
Post by Rorybeanbutler » Mon Feb 22, 2016 3:54 pm
51481915964 that's the product code buddy. I got them from my local BMW dealer. http://www.realoem.com/bmw/enUS/showpar ... Id=51_4961
It's number 2 on this link.
z4 coúpe gone. C30 r design arrived.
Online
flimper
Post by flimper » Mon Feb 22, 2016 4:29 pm
cheers!
Piano black & black extended leather. Power mirrors, tinted glass, PDC, Prof hi-fi, CD, retro-fit cruise
Pete1726
Post by Pete1726 » Sat Jul 29, 2017 12:29 pm
Hi thanks for the step by step with pictures it has worked a treat. :D :D :D
Pete
LJSteve
Post by LJSteve » Mon Dec 11, 2017 4:43 pm
Thank you so much sk93.
It took me closer to 90 minutes because I am not practiced or particularly gifted under the bonnet - and getting the wiper blades off was very time consuming, perseverance was the key! However, even I was able to achieve the desired effect using your brilliant guide. Thanks again :D
HarryD
Post by HarryD » Sat Dec 16, 2017 11:35 pm
Nice post. I will need to do this to my 2003. One question. To remove the wiper arms, any reason to not use a battery terminal puller like I do on my other cars?
Harry
1970 VW Sunroof Bus - "The Magic Bus"
1973.5 911T Targa - "Smokey"
2003 BMW Z4
2009 MB C300
Smartbear
Post by Smartbear » Sun Dec 17, 2017 2:20 am
I don’t see why not, as long as it pulls the wiper up from its spline it should do the job :thumbsup:
e89 Sdrive2.0 20i, plenty of mumbo & good economy-the thinking bears z4 :P
e89 Sdrive30i this ones busted, pass me another...
e85 3.0si, i foolishly sold my trouble free car...
HarryD
Post by HarryD » Mon Dec 18, 2017 11:23 pm
Just did the repair. No at all hard. Took me about 1 1/2 hours because I am slow.
Some observations:
-My cowl cover did not have any of the 4 front pins in place. I just put it back. We will see.
-The windshield wipers came right off. Not at all like the ones on my bus that always require a puller.
-The retaining clip for the electrical connector broke off. (Car has 120,000 miles). Put some dilectric grease on it and pushed it back together. Hopefully it will hold.
-The drain under the moter was filled with nasty gunk. Vacuumed it out and clead the rubber flappy thingy.
Thanks for a great DIY Article!
Harry
2003 BMW Z4
2009 MB C300
csquire4
Post by csquire4 » Mon May 28, 2018 9:23 am
Great guide, thanks fella. Did this yesterday, took about 3hrs as I am useless so I work slowly and it took over an hour to get one of the wiper arms off.
Opening up the motor and cleaning the grease took 10 mins, that was the easy bit!!
There wasn't much debris behind the cowl but I take the opportunity to clean it properly and apply some Gtechnic back to black stuff.
2004 3.0i, manual, toledo blue
mjennings23
Post by mjennings23 » Mon May 28, 2018 6:18 pm
I'd also like to add, if your wipers are returning to the bottom and then moving back up before stopping, it could also be a worn relay as was the case for me. However still happy I cleaned the motor out, found a massive pile of crap under the scuttle!
legacy4cam
Post by legacy4cam » Mon Jun 04, 2018 3:50 pm
My wipers are parking up the screen a bit and I have cleaned the motor switch plate , what relay do you refer to and how does a worn relay contribute to this issue? It doesn't happen all the time, but does waste the car when its parked and they look broken, lol.
Thanks.
Iain
Zequipe
Post by Zequipe » Thu Aug 16, 2018 8:59 pm
As a fairly new member , I have used this guide to fix the wiper resting issue.
It is extremely well written.
So, a Big Thank You to the author.
Online
Jl-c
Post by Jl-c » Thu Sep 06, 2018 10:17 am
Just as an addendum to the great “how to” use brake cleaner to flush all grease out and re-grease (should you choose to) with vaseline, it doesn’t conduct. Never use copper grease on pivots it sets hard eventually, use silicone grease. Just my 2p worth! Great help though and thanks.
E86 Z4 3.0si coupé facelift blue (with heated M seats, bluetooth, privacy glass, xenons, M suspension, 160Gb Ipod. etc)
Porsche 997 C2S black, VW Passat 2.0L black, Mazda Eunos 1.8 yellow.
Russblade
Post by Russblade » Sun Mar 10, 2019 2:04 pm
Arghhhhhhhh desperate to do this, cannot for the life of me get the arms off
Tilly
Post by Tilly » Sun Mar 10, 2019 2:22 pm
I got a wiper arm removal tool online to do mine as they were really locked on!
Russblade
Post by Russblade » Wed Mar 20, 2019 9:35 pm
Happy days, looks like it worked a treat, need to replace a few snapped fittings though
