Key sorted by Bmkeys
- Bahnstormer
Cheers Chim_lad ,
Key posted to Carkeyrepaircompany. Will report back when the key returns !
"Tower, this is Bahnstormer, requesting a flyby !"
08 Silver Coupe 3.0si
- Mikopop
Surely if you have security concerns you just get the key sent to your in laws or brother/sister/aunt/granny etc away from your home. Problem solved.
2009 E89 2.3 silver
- Bahnstormer
Good idea. Should have thought of that !!!!
- aqua0
I looked at this as they’re only 5 miles away from me. Contacted the seller and asked if I could drop my key off rather than post. Seller refused stating they only deal by post!Chim_lad wrote: ↑Mon Jun 22, 2020 3:48 pm
I used Carkeyrepaircompany - https://www.ebay.co.uk/itm/273540436092
Keys2u
16a Golden Hill Lane
Leyland
Lancashire
PR25 3NP
£19.99 and no complaints about the service
Quick google earth check has the property listed as an Indian takeaway??
Never go deeper than the bottom
Facelift 3.0Si Roadster
Previous was a 2.0i Sport
I’ve just had my second key done and returned. No takeaway menu included in the envelope thoughaqua0 wrote: ↑Sun Jul 05, 2020 10:26 amI looked at this as they’re only 5 miles away from me. Contacted the seller and asked if I could drop my key off rather than post. Seller refused stating they only deal by post!Chim_lad wrote: ↑Mon Jun 22, 2020 3:48 pm
Keys2u
Leyland
Lancashire
PR25 3NP
5 wheels and a folding roof
- MrPT
Does replacing the battery restore the range to more than 7 millimetres?
2006 Z4 2.5si: gone
2006 Z4 2.5si: gone
- aqua0
- Bahnstormer
Key came back next day and worked , but had a bad battery (and wouldn't hold the settings for the car).
This was replaced by CarKeyKing/Keys2U along with emails back and forth telling me what he was doing etc. Great service.
2nd Key working fine. I would use them again.
- buzyg
Good shout.Chim_lad wrote: ↑Mon Jun 22, 2020 3:48 pmI used Carkeyrepaircompany - https://www.ebay.co.uk/itm/273540436092Bahnstormer wrote: ↑Mon Jun 22, 2020 12:59 pm Cheers Chim_Lad - Can you post the company you used - would be good to use them.
Keys2u
Leyland
Lancashire
PR25 3NP
- Roberltd2
Just clicked the link only to read: "This listing was ended by the seller because the item is no longer available."
My spare had also stopped working remotely, so I bought the correct replacement battery, split the key case and fitted it but, alas it still would not work.
So ,in other words (I'm now thinking), if you replace the battery, you also have to have the key recoded to make it work remotely?
2007 E85 2.5 si Sport in Montego Blue.
1994 Eunos J2Ltd - sold and now undergoing restoration.
1963 Triumph Thunderbird.
- alane29
No thats not the case, key should work if the battery is replaced unless there is another issue
2007 E86 M Coupe
2005 E85 2.5SE
2005 E85 2.5SE
- Roberltd2
Ok. Thanks for the reply.
Anyway to find out if this guy is still doing the key repairs?
- Zulu4
I found it quite easy to change the battery.
Order the rechargeable battery from Aliexpress, cut the fob open with a sharp blade, desolder / resolder battery, super glue all back together, mask BMW logo & blade, spray case with matt black. Then place on toothbrush charger overnight for good measure.
Cost about £5, looks almost new.
2007 3.0si Auto Sport Roadster. Whippy.
Previous:
2003 3.0i SE Roadster. Whippy.
Previous:
