I've just (finally) done the checking of my drains, and rather surprising - completely clear
still good to know
Power roof problem
- gannet
Re: Power roof problem
-- Gannet.
Current: MINI JCW... - Modification: Driver Upgraded
Previous: DS3 DSport, Z4 3.0SE, 206 GTi & XS, Alfa 147 Lusso
- Tweed
Going to do mine next weekend; putting new discs, pads and sensors on, and I believe you can get access to the bottom of the drain when you take the cover for the brake wear sensor off, put a hoover to it and suck out the crap that way?
For the OP, I think the first thing I would do is lubricate the mechanism. There's a post about it somewhere around here, I believe it was said that bike-chain oil was the thing to use, while the hood is half up to give good access.
wasupdu: if the dealer's replacing your motor, they should replace it with the newer version, which is a sealed unit and doesn't have the same problem of getting water-logged. Probably still a good idea to clean your drains though (or make the dealer do it when they have the hood off )
Tweed/Nick | http://pixelenvy.co.uk
- Jay9K
Sounds like your motor might be on it's way out, mine failed over the winter and had it replaced by BMW in Chigwell cost £700.
Shipkiller has DIY instructions on replacing the motor and clearing the drians that cause the issue.
http://www.zpost.com/forums/showthread.php?t=333198
good day
i just this morning got the same problem, it was slow to retract and open
and just stop after, no more movements. i washed my car the evening before, it' a 2006 3.0 ie. is these year came with the upgrated motor? before i' m looking to replaced it,what should be done before ,to be sure it's the problem, i clear the drain hole it seems o.k.
thank you
thank you
- tomrdy
Power roof problem
People delete the rubber thingy??! I put mine back in
Well, my contribution to this thread - if you happen have your side skirts off for whatever reason, another way to clear the holes!
When I had my side skirts off for my wrap, I accidentally found it (it fell out) and I was like "what's this??!".
Wasn't even thinking about the drains at the time but checked they were all clear and popped the rubber back in.
I am in Australia though so maybe for the best as I did find black widows in my side skirts haha.
-SOLD- Nardo grey 2004 Z4 3.0i E85
-SOLD- 2016 Long Beach Blue M2 DCT
-Wishing- Z4MC Interlagos blue...
___
Australia
