Abs light and handbrake light, consistently orange
So today we have managed to get rid of the lights, diconnected the battery and then braked sharply a
Couple of times and the lights have gone off, what does that mean? Dodgy sensor? I initially thought it was the abs pump but not sure now we have managed to get rid of the lights! Anyone have any idea?
2007 2.0 BMW Z4- Blue
- maxman
They will come back on within a few miles,see previous comments.
Ah I see, yours was just a sensor though wasn't it?maxman wrote:They will come back on within a few miles,see previous comments.
- maxman
Yes .The two on the pump.Charlie1100 wrote:Ah I see, yours was just a sensor though wasn't it?maxman wrote:They will come back on within a few miles,see previous comments.
So lights have come back on about a week after we turned them off, does that point towards sensor or the whole unit like the garage said? It's really hard to get a definitive answer and although the garage said it was the abs pump, is it worth trying the sensors first?
- enzed4
2A70 Valvetronic Servomotor
2C6E Lambda Sensor Post Cat 2 Timing
P0159 - O2 Sensor Circuit Slow Response Bank 2 Sensor 2
None of those codes seem to relate to the ABS/DSC. It would have been nice if the garage you took it to gave you a copy of the fault codes they found.
Whether it is the Pump Motor, or the ECU attached to it, either can (usually) be fixed for a fraction of the cost of a replacement pump or ECU.
Charlie1100 wrote:Hi All,
I have got an App on my phone which has read the codes but it only seems to be a basic one, is there an app which is close to being free and tells you more?
Anyway I got the following error codes:
P2A70
P2C6E
P0159
The app didn't seem to help, can anyone guide me on what this is?
Gone: 2010 35i DCT
Gone: 2008 2.5Si Sport
- Paulr
I had my handbrake light and my brake light come on at the same time. Googled it and evidently the wheel sensors can get very dirty. On each wheel is a plastic ABS sensor at the back of the calliper, they remove with one Alan bolt and a bit of wiggling. I cleaned mine with brake cleaner and a cloth, has not come back on yet after a week and a few hundred miles of driving.
Might not be the same thing as my ABS light did not come on, but may be worth a look into.
If you try and take a cat apart the first thing you have is a non working cat.
These were not the fault codes that I had when my ABS pump unit went. You need to get some reliable garage to read the codes and tell you what is wrong.
If it is the ABS unit, £350 for parts and labour is a bargain.
The seller seems to have been rather disingenuous with this, I wouldn't be surprised if he took it to BMW himself and baulked at a £2,000 estimated repair bill and quickly sold it on.
2008 Z4 2.0i SE E85, Space Grey, 18" 241 staggered rims, 255/35/18, 225/40/18, 2 tone anthracite/silverstone leather Msport heated seats, M sport MFC Steering wheel, Bluetooth, Comfort pack, Tracker, Automatic climate control, Gaptech, Blah, blah.
- enzed4
What Geezah said - get the codes read before worrying about what it might or might not beGeezah wrote:These were not the fault codes that I had when my ABS pump unit went. You need to get some reliable garage to read the codes and tell you what is wrong.
5DF0 & 5DF1 are (often the) pump motor codes. Mine just got back from an overhaul, fingers crossed it's fixed for good (haven't had time to put enough miles on the Z4 to tell yet).
I believe other codes relate to the sensors, e.g:
5e24 pressure sensor 1/2 not plausible
5e20 pressure sensor
Gone: 2010 35i DCT
Charlie - where are you based?
I had same problem, put it on diagnostics, it was a brake pressure sensor, bought a new one from dealer (via ebay), took mechanic 2 minutes to fit and then bled the system. (don't buy the cheap chinese versions)
http://www.ebay.co.uk/itm/Genuine-NEW-B ... 3d294df0e4
2004 3.0i, manual, toledo blue
Hi All
I am a newish member! Joined last year but my z4 3.0si convertable has been parked up and unused for a year, she has only done 26k 2k in the last 3 years. Foolishly, I went to a none BMW and had diagnostic done at a cost of £50. I have just had same done at a local electrical engineer as someone had mentioned after a new battery the car needs reprogramming hence another check £50 poorer earlier today and same code fault 5DF 0 and 5DF1.
I have found a company that refurb with lifetime warranty for around £200 ECUTESTING.
One last thing to mention, I read also somewhere pushstarting and using jump leads can affect (any advice on this please?) which she was subjected to!
Promise pics when she has been cleaned
Kolaz4
Kolaz4
- enzed4
Hi and welcome. You didn't mention what Z4 you have: E85/E86 or E89. Difference being the E85/86 doesn't need the battery registered after replacing, the E89 does (from my understanding). You might find the 5DF0/5DF1 codes are for the hydraulic pump (stuck brushes) and not the module; I'm not sure ECU testing fix the pump? Hopefully they do either the pump or the module depending on which one is faulty.
Kolaz4 wrote: ↑Fri May 11, 2018 6:19 pm Hi All
Kolaz4
Gone: 2010 35i DCT
Hi all
Enzed thanks a mill for your response. Mine is an E85/E86. I will call ECU... and check out.
I had a 300plus mile drive to Gloucester and back over last two days; home run with roof down and sunshine
Hairy drive on country lanes on run flats!! Any advice on replacement tyres ASAP please as I am changing them next week. My local Tom Tully promoting DAVANTI.
Thanks all much much appreciated
Ps pics tomorrow as I will be cleaning of massacred flies!
- enzed4
Many many threads on here about good tyres to replace the runflats with (don't forget to kep a tyre repair/selant kit in the boot in case of flats). We would need to know what wheels you're running to recommend tyre sizes.Kolaz4 wrote: ↑Fri May 18, 2018 9:19 pm Hi all
Might pay to post up some pics (we love pics...) of your Zed as an introduction in the newbies thread as well.
Cheers.
Gone: 2010 35i DCT
