SMG Help
McDade
SMG Help
Post by McDade » Mon Jun 10, 2019 9:54 am
Excellent, thanks very much
Did you buy your pump refurb or did you purchase one from SMG Society?
Thanks again
2018 Jaguar F Pace R - The Daily Drive
2003 BMW Z4 3.0i, Black wi/ Red, SMG - The bit on the side
bladeowner
SMG Help
Post by bladeowner » Mon Jun 10, 2019 1:35 pm
I bought a new one from SMG Society. They have a web page but also were on Ebay. As luck would have it Ebay had a 10% off voucher at the time and so it was a bit cheaper on Ebay.
2004 Sapphire Black 2.5 SE Z4 SMG
Tonycat0
SMG Help
Post by Tonycat0 » Thu Jun 20, 2019 2:37 pm
Can anybody help with a reasonable value mechanic for renewing the clutches on my 2003 Z4 SMG box? I am located East of Nottingham.
McDade
SMG Help
Post by McDade » Tue Jun 25, 2019 2:24 pm
bladeowner wrote: Mon Jun 10, 2019 1:35 pm I bought a new one from SMG Society. They have a web page but also were on Ebay. As luck would have it Ebay had a 10% off voucher at the time and so it was a bit cheaper on Ebay.
Pump purchased, should be here this week for fitment. Will update you all when i hear back
bladeowner
SMG Help
Post by bladeowner » Tue Jun 25, 2019 11:38 pm
McDade wrote: Tue Jun 25, 2019 2:24 pm
:thumbsup:
McDade
SMG Help
Post by McDade » Thu Jun 27, 2019 1:15 pm
I am struggling to get the the power connector disconnected on the current pump? It appears two connectors click together but i cannot release them. Additionally the earth mount seems to disappear into the car somewhere. Does this need unscrewing from underneath the bonnet?
thanks
bladeowner
SMG Help
Post by bladeowner » Thu Jun 27, 2019 2:41 pm
The connector needs to have the locking catch activated but I can't remember which way you press it. Picture below of motor side connector. The earth strap connects to a bolt on the gearbox if I recall.
The bit on the top has a pawl that needs to be released by pressing on the loom connector.
bladeowner
SMG Help
Post by bladeowner » Thu Jun 27, 2019 2:45 pm
As you pull the motor off the fluid will pee out of reservoir - you need to catch it or buy some more :) There is an O ring seal in the reservoir that seals the joint to the pump. Don't lose it. As you are just changing the motor, the hydraulic side stays all primed and so if you do lose fluid just top up the reservoir when it's all back together. I needed a bright torch to be able to see the reservoir level when refilling.
You can see length of earth cable below
bladeowner
SMG Help
Post by bladeowner » Thu Jun 27, 2019 2:58 pm
PS I think the motor connectors where also held on the car on a bracket and you had to turn it like a bayonet fitting to release it from it's bracket
McDade
SMG Help
Post by McDade » Sat Jul 06, 2019 8:25 pm
Today I finally managed to get the time to fit the new motor pump, after around 5 hours of getting soaked in hydraulic oil I managed to get the system primed and the motor is now shifting between 1st and neutral
For the first time in around 12 months I managed to start it!
This is a massive milestone and I have a list of things I need to get sorted before it’s road worthy but I’ve set myself a target of 18/08/2019 (ZedFest) to have this on the road so I can meet as many people as possible who has helped me on here and buy them a beer (or 5)
Will keep you posted on my progression and I will be writing a blog post to help others in the future
bladeowner
SMG Help
Post by bladeowner » Sat Jul 06, 2019 11:22 pm
Good news :thumbsup: btw I got soaked in oil too :o
McDade
SMG Help
Post by McDade » Thu Jul 11, 2019 10:23 am
Quick update, i may change this thread from SMG help to My Z4 Project:
So after been able to finally start the car, the car was hopping around on idle and then stalling. After some investigation it appears the air intake hose has perished, and the idle control valve appears to be clogged and isnt opening/closing. I have removed the air intake hose and have one on order (BMW 13547514867) and have attempted to clean out the ICV.
List of items to tackle:
Front Suspension coil spring
Brakes pads/disks
Bonnet lock mechanism
Valve Cover Gasket
Service
Slowly ticking through these, i am hoping to have the suspension coils changed this weekend along with pads disks and air intake should it arrive
Photos below:
tube split.jpg (195.08 KiB) Viewed 834 times
tube close.jpg (134.51 KiB) Viewed 834 times
engine bay.jpg (252.16 KiB) Viewed 834 times
McDade
SMG Help
Post by McDade » Tue Jul 23, 2019 9:38 pm
Little update
The ICV and air intake hose was replaced and it’s now not bouncing and stalling on idle.
Air Filter quickly swapped
Next stop is suspension and oil change. MOT should be booked next week 👍
greypride
SMG Help
Post by greypride » Thu Jul 25, 2019 10:10 am
I ordered a motor for the SMG pump from SMG society last week. it arrived in a few days with some instructions. Fitted yesterday...
Did it on the drive with a trolley jack and axle stands - bloody hell these cars are low!!
Instantly it sounded better, the whine noise it makes when priming was faster and more purposeful. Driving it is much improved; the shifts are faster and smoother..
Full credit to SMG society and my mate Nathan who fitted it for me, i'm happy again!
PS, Nathan is going to pull the motor apart and see if can be refurbed.. i shall report back...
parabolica
SMG Help
Post by parabolica » Thu Jul 25, 2019 11:06 am
Good to hear it went well; my SMG is on 71k miles and 16 years old - so far no issues but I'm sure one day the time will come...
