pull away shudder! :-( E86 3lt. 125'000.
Hi Gents/Ladies.
Bit of strange one here but hopefully some one has an idea or a direction I can look into diagnosing the problem.
Basically when the engine is under strain I randomly get a shudder. When I say under strain it's most noticeable below the 2k rpm mark and when in say 5th or 6th gear (lazy driving) and just generally pulling away. Sometimes I've noticed if I accelerate gently it's fine but if I put my foot down it appears. I've recently noticed it a couple of times in 1st gear when pulling away harshly which is why I'm getting more concerned.
Sparks are fine and I've cleaned the coils which look ok but I think are the original packs. i don't think it's these however because sometimes the car appears fine.
Feels like she's struggling and shuddering slightly at the same time. I was wondering if it could be the fuel pump/filter or injectors maybe? I've tried running cleaners through the fuel and nothing noticeable has changed.
Any ideas would be much appreciated or tricks I can check to get me started?
Cheers in advance.
Regards,
Lee.
Cheers in advance.
Regards,
Lee.
- Smartbear
Hi, at your mileage it could be the dmf developing some slop
e85 3.0si sold
Could this be the clutch/fly wheel giving up ??
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
- Ducklakeview
+1 pointing at the DMF. Is it "rattly" when idling?
Mike
Mike
Cheers for the replies Gents.
No no rattles, sounds to be in pretty good condition if I'm honest. Even when revved. Clutch I'm sure is fine as there's no slip, even on harsh acceleration and after just looking at a few videos on YouTube definitely doesn't sound anything like them. The shudder feels more like a misfire but without the noise if that's any help?
Cheers again,
Lee
Cheers again,
Lee
What petrol are you using ? Main brand, supermarket and what octane ?
- Smartbear
It's an e86 with the n52 engine, it will run fine on normal unleaded-this sounds like a fault rather than fuel grade issuesraymond.harper wrote:What petrol are you using ? Main brand, supermarket and what octane ?
e85 3.0si sold
- MACK
I wouldn't rule out the coils, electric faults can be intermittent and sparks/coils etc starting to fail do tend to manifest under load at first. Obviously its difficult to say and it could be a multitude of things, do you have access to a scanner/diagnostic equipment etc just to see if there are any codes stored already?
Silver 05 3.0i SE
White E89 20i M Sport
Hi Gents,
I've literally just had the EML turned off due to o2 sensor post cat needing to be changed. No other faults were found. :-/
I've noticed today a little rattle inside the car when out of gear. If I put my foot on the clutch it disappears so maybe there is an issue with the DMF after all.
I had the issue this morning with the juttering again. Took the car out of gear and just revved noticing it was still doing it?! I turned the car off and on a couple of times and the problem disappeared.... I'm very confused!
Cheers again for the replies.
I had that problem on my smart roadster. it ended up being the clutch actuator. not sure if it wil be the same on the zed but could be worth a look.
when you are at low speeds does it jerk forwards?
- maxman
On one car we had when setting off from a standstill it had a quite severe judder.Turned out to be the centre bearing on the prop shaft.
Hi Gents,
No, no jurking forward just a stutter/judder when under load and a few times when just sitting there revving it's jittered up the rev range. Turn off then back on a few times and it appeared to have gone.
I don't think it's anything to do with the clutch but more to do with fuel or coils. Feels more and more like it's missing the occasional beat. :-/
Cheers again.
Cheers again.
- Smartbear
It won't be that, the smart uses a robotised manual engine, the zed has a normal slave cylinder for clutch actuationMactran wrote:I had that problem on my smart roadster. it ended up being the clutch actuator. not sure if it wil be the same on the zed but could be worth a look.
e85 3.0si sold
well thats my suggestion out the window. thanks for clearing that up Rob. could have ended up wasting this poor chaps time. sorrySmartbear wrote:It won't be that, the smart uses a robotised manual engine, the zed has a normal slave cylinder for clutch actuationMactran wrote:I had that problem on my smart roadster. it ended up being the clutch actuator. not sure if it wil be the same on the zed but could be worth a look.
Not at all Mactran, any suggestions are very welcome! There things I can look into. Is there any way of checking the coils and testing them or just the case of buying a few new ones first and swapping them around with the old?
