How do you remove lining from Z4 hardtop?
- Chris_D
Excellent write-up kis and I'm sure this will help others too, maybe including myself - I'm thinking about adding extra insulation (2mm adhesive mat) between the top shell and lining for even more of a cosy,quiet feel
I'd expect it to be made of GRP or some other rigid polymer material although I initially thought it was a thin steel panel due to the sheer weight of it.
- Marlon
I though it was steel too?
Gone: 3.0si 2008 E85
911 997 Carrera S
- kis
May well be!Marlon wrote:I though it was steel too?
However due to the weight I thought its too light for steel? Unless as Chris said it's only a thin sheet...
Chris_D wrote:I initially thought it was a thin steel panel
One of the fasteners nicked its housing in the hardtop as well... this showed that same white resin/glass fibre type material. So that's why I said resin. May well be a predominant thin steel sheet which is moulded with the resin to form the overall shape?
My E85 Z4 3.0i SMG
1 Series - E87
4 Series - F36, F82 M4
5 Series - E34 (x2), E39
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
- kis
Cheer Chris. I was thinking the same myself! I'm rocking the no trim look in the car at the moment! hahaChris_D wrote:Excellent write-up kis and I'm sure this will help others too, maybe including myself - I'm thinking about adding extra insulation (2mm adhesive mat) between the top shell and lining for even more of a cosy,quiet feel
My E85 Z4 3.0i SMG
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
- Chris_D
lol hardcore! i bet it's noisy as hell too when driving?kis wrote:Cheer Chris. I was thinking the same myself! I'm rocking the no trim look in the car at the moment! hahaChris_D wrote:Excellent write-up kis and I'm sure this will help others too, maybe including myself - I'm thinking about adding extra insulation (2mm adhesive mat) between the top shell and lining for even more of a cosy,quiet feel
Looking further at your pic with the lining removed it could even be a composite with a central square section of steel. that would make sense in terms of adding some structural integrity/rigidity while retaining sufficient flexibility for a good fit etc.
My mum's MGB hardtop has a big glass/polycarbonate roof section - almost the entire roof space and it's actually more rigid than the same hardtop without the roof window panel - the reason: it's a stiffer material than the grp roof. makes sense.
Last time I saw it on her car I made the fundamental mistake of asking her 'when was the last time you had it off?' her reply: 'oh you'll have to ask your father about that dear.' priceless.
- kis
It's not actually as bad as I thought it would be, then again the trim piece isn't exactly sound proofing in itself. It's just an aesthetical cover up... so far as I can tell anyway.Chris_D wrote: lol hardcore! i bet it's noisy as hell too when driving?
Chris_D wrote: Last time I saw it on her car I made the fundamental mistake of asking her 'when was the last time you had it off?' her reply: 'oh you'll have to ask your father about that dear.' priceless.
Oh dear
My E85 Z4 3.0i SMG
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
- kis
Chris_D wrote: Looking further at your pic with the lining removed it could even be a composite with a central square section of steel. that would make sense in terms of adding some structural integrity/rigidity while retaining sufficient flexibility for a good fit etc.
Just done a hard and fast test, I figured what is it made of then?? So I did the only thing I couldMarlon wrote:I though it was steel too?
LOL just kidding! I did the magnet test. The only thing magnetic in the top is the a pillar section (left and right) where it bolts down onto the car. There must be a small section of metal there that's moulded somehow into the hardtop.
So not made of steel! ....Unless it's made from alu?
My E85 Z4 3.0i SMG
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
- Chris_D
interesting. would have expected maybe a steel panel or at least a frame. quite possibly aluminium then. who knows...?kis wrote:Chris_D wrote: Looking further at your pic with the lining removed it could even be a composite with a central square section of steel. that would make sense in terms of adding some structural integrity/rigidity while retaining sufficient flexibility for a good fit etc.Just done a hard and fast test, I figured what is it made of then?? So I did the only thing I couldMarlon wrote:I though it was steel too?
either way it's a decent hardtop imo and i'm very glad to have found one, especially on days like these. 2degrees in vleuten this morning. brrr
- kis
I'm sure someone out there does!Chris_D wrote: who knows...?
And agreed, makes a big difference with it on imo. Also prefer the shape with the top!
My E85 Z4 3.0i SMG
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
- DMC63
Thanks for taking the time to post these pics Kis...I sleep like a log now and have cancelled the sessions I'd booked with the shrinkMarlon wrote:Great detailed reply kis, along with lots of really useful pics - should help DMC63 sleep and avoid the shrink.
It never fails to surprise me how helpful the members of this forum are. Gratitude moment And some great humor too
BMW Z4 2003 2.5i and lots of bits and pieces - 2016 - 2020 Sold
- kis
Welcome mateDMC63 wrote:Thanks for taking the time to post these pics Kis...I sleep like a log now and have cancelled the sessions I'd booked with the shrink
My E85 Z4 3.0i SMG
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
- DMC63
I was told they're fiberglass. Maybe an email to BMW HQ would reveal the specs....I'm going to email them nowkis wrote:May well be!Marlon wrote:I though it was steel too?
- kis
Nice one! Keep us updated!
My E85 Z4 3.0i SMG
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
Had to remove my lining from my Z4 hardtop as the glue failed after fifteen years. Thanks to kis and all for this thread , the job was much easier than expected. Did anyone have to replace the three hidden plastic clips in the head liner, forward of the rear window?
BMW Z4 3.0i (Dinan Stage III) Roadster w/hardtop
- kis
You're very welcome! Exactly why I posted the pics... although quality of the photos looks diabolical! I've a much better camera on the phone now
Not sure what 3 hidden clips you mean? Photos might help
My E85 Z4 3.0i SMG
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
