Help, I've knackered my paint.
w1ndsurfnut
Post by w1ndsurfnut » Tue Aug 02, 2016 10:26 pm
This is my car before I Messed it up. Will try and get a photo up of the paint surface tomorrow. Its a 2003 2.5 auto and one of the best things about it given the age was the state of the paint. Anyway she has been laid up in my garage for months due to the rocker cover gasket needing doing and various other things. The garage is under construction so I have been cutting some natural stone which created a lot of fine dust. This ended up sitting on the car for a long time. Just taken it down the local jet wash as an initial start of cleaning it thinking it would all just come off. Its only dust right. Wrong. The surface feels terrible, like there is grit stuck to it ,and up close it looks like rust coloured bits on the surface of the paint. They pick off with your thumb nail. But there is still a rust coloured mark on the paint. Tried a quick polish with auto glym as a test and its not really dealing with it. Any help/advice would be greatly appreciated. My initial thought is claying the whole car, but I have never done this. Really pissed off with myself for neglecting her in this way. I hate self inflicted problems. :headbang:
Marlon
Post by Marlon » Tue Aug 02, 2016 10:31 pm
Nightmare - the detailing boys will be along soon and can hopefully help you out.
Gone: 3.0si 2008 E85
911 997 Carrera S
w1ndsurfnut
Post by w1ndsurfnut » Tue Aug 02, 2016 10:37 pm
I hope so Marlon. Feeling pissed off at the moment.
srhutch
Moderator
Moderator
Post by srhutch » Tue Aug 02, 2016 10:40 pm
If you have been using a cutting disc nearby you will need some iron-x or similar to remove the fallout.
I'd probably foam, gentle wash, iron-x, tardis, and then clay. Wash again the protect.
HubertK
Post by HubertK » Tue Aug 02, 2016 10:56 pm
Grab your self couple clay bars and set aside a good 5-10h shift if it's all over your car. I would recommend bilt hamber clay and korrosol if the "dust" is iron particles.
HelenZ4
Post by HelenZ4 » Tue Aug 02, 2016 11:05 pm
Might be tempted to let a local expert see it before having a go yourself just in case.....
Hope all goes well.
Whereabouts are you?
2008 3.0Si Sport Monaco Blue Individual Champagne Nappa Bi-colour Interior Heated Seats Comfort Pack Xenons Bluetooth BBS CK's BMW Stubby. ZX636A1P 2002 Snot Green A1 mint, Beowulf can, low miles goes like stink. 15 plate C220d Estate AMG PremPlus
Angie4m
Post by Angie4m » Tue Aug 02, 2016 11:59 pm
srhutch wrote:If you have been using a cutting disc nearby you will need some iron-x or similar to remove the fallout.
Plus 1 on this. Definitely going to need a clay. It'll be time well spent.
Deep Sea Blue sDrive35is - I LOVE IT! Best car I've ever owned :) - Gone
RRS V8 Supercharged - Gone
Abarth 595 Competizione - Gone
Yas Marina Blue M4 Coupe - Gone
Current:
Protonic Blue i8
Amethyst 997
F56 JCW Challenge (19 of 52)
Still Shy and retiring
Smartbear
Post by Smartbear » Wed Aug 03, 2016 12:08 am
Clay mit, loads faster & pretty much the same job :thumbsup:
Should be ok if you don't rush it.
e85 3.0si sold
Yorkie Z
Post by Yorkie Z » Wed Aug 03, 2016 6:46 am
That's not dust mate, that is from the cutting disc itself. You have burnt in to the lacquer.!!!
A Dirty M///
Z4M-2006
Post by Z4M-2006 » Wed Aug 03, 2016 7:18 am
This...
You might be able to save it, I would head to your nearest professional detailer and keep your fingers crossed..
Depending on how bad you have damaged the paint, be prepared for quite a bill
w1ndsurfnut
Post by w1ndsurfnut » Wed Aug 03, 2016 9:58 am
HelenZ4 I'm in rural France near Cognac. Thanks for all the replies. I'm going to have to tackle this myself as I have no idea where I would get this sorted here.
w1ndsurfnut
Post by w1ndsurfnut » Wed Aug 03, 2016 11:36 am
HubertK wrote:Grab your self couple clay bars and set aside a good 5-10h shift if it's all over your car. I would recommend bilt hamber clay and korrosol if the "dust" is iron particles.
I have been looking at the clay you mentioned. it comes in 200g pots and 3 grades. I was thinking of getting all 3. Is 200g enough to do the whole car. I'm totally new to this level of cleaning/detailing. :?
Z4M-2006
Post by Z4M-2006 » Wed Aug 03, 2016 11:47 am
If you buy 3 x200g of varying bars you will have enough...
I think I would probably get the heaviest grade initially and see what happens...
May save you a few quid in the long run
Dietcokeman
Post by Dietcokeman » Wed Aug 03, 2016 12:25 pm
Smartbear wrote:Clay mit, loads faster & pretty much the same job :thumbsup:
^^^^ this
The iron x is also a good call. The nature of cutting discs and the heat generated means that disc debris can and will burn into any surface it lands on . Paint work and glass are easily damaged by this . Check your windscreen and Windows etc too !
w1ndsurfnut
Post by w1ndsurfnut » Wed Aug 03, 2016 12:51 pm
^^^^ this
Thanks Dietcokeman, I think. It just gets better and better.
