Roof Motor Relocation, in pictures
- Number5
There's a lot of talk about Roof Motors at the moment and a quest for more info, so here's a few pictures from one I recently did for a forum member.
The Car with the roof out:
The opportunity to unblock the drains, whilst access is easy and visible
The roof on the floor with the motor attached: The rusty motor unwrapped from its housing: Continued in next post ( as only 4 pics permitted as attachments)
Alpina Roadster #307
Porsche Boxster GTS
Previous Zs
Stratus E86
G29 30i
1x Imola Z4MR
Alpina #019
10x E85 Se/Si Roadsters
2x E89's
Porsche Boxster GTS
Previous Zs
Stratus E86
G29 30i
1x Imola Z4MR
Alpina #019
2x E89's
- Number5
The motor in its new position, in the boot
The Final product, with motor behind a false panel;
Just like that... with a bit of hoovering to go !
The motor with its housing back around it for protection, but with the wet foam removedThe Final product, with motor behind a false panel;
Porsche Boxster GTS
Previous Zs
Stratus E86
G29 30i
1x Imola Z4MR
Alpina #019
2x E89's
Porsche Boxster GTS
Previous Zs
Stratus E86
G29 30i
1x Imola Z4MR
Alpina #019
2x E89's
That looks good if you know how to take the roof out, when I had mine done in Durham, didn't need to take the roof out, it was carried out with the roof still in situ
- Number5
I suspected that the chap up there doesn't take it right out, hence the amazing price he manages !.olsonn wrote:That looks good if you know how to take the roof out, when I had mine done in Durham, didn't need to take the roof out, it was carried out with the roof still in situ
However, it is a good opportunity to clear the drains properly, as we've recently done one, where the passenger side drain was totally blocked and it took about 30 minutes of all sorts of rodding to unblock. No way we could have cleared it with the roof still in.
Porsche Boxster GTS
Previous Zs
Stratus E86
G29 30i
1x Imola Z4MR
Alpina #019
2x E89's
Porsche Boxster GTS
Previous Zs
Stratus E86
G29 30i
1x Imola Z4MR
Alpina #019
2x E89's
- mac27040
Heres mine, i cannot get mine in the same ways as your due to the TV module and other bits behind the carpet.
Roof motor relocated
new cardboard boxing with carpet stapled on
finished look
finished look
3.0i SMG Supercharged,19" CSL, AvinUSA android 10.25” screen,DSP,M6 gearknob,Coilovers,Aero F-bumper,M r-bumper,Aero skirts,Facelift front & rear lights,M sports seats,Carbon Steering wheel,Intravee,Rervese cam,Hydrographics
- Marlon
Great pics thanks.
So having the motor angled at 45 degrees doesn't cause any problems then?
Gone: 3.0si 2008 E85
911 997 Carrera S
- Smartbear
As long as the hydraulic fluid is covering the bore hole it will work as normal, I should think that 90 degrees would be pushing it, but 45 seems fineMarlon wrote:Great pics thanks.
e85 3.0si sold
- Ducklakeview
The motor is roughly at that sort of angle in it's original location. Just make sure the fluid reservoir is on top obviously!
Mike
- David-H
He certainly does take it right out and positions it in the same place as you did, held in with ties and then a carpeted cover fitted.Number5 wrote:I suspected that the chap up there doesn't take it right out, hence the amazing price he manages !.olsonn wrote:That looks good if you know how to take the roof out, when I had mine done in Durham, didn't need to take the roof out, it was carried out with the roof still in situ
BMW Z4 3.0i auto ¦ Titanium Silver
107's : Drexler LSD
BMW M6 Gran Coupe ¦ Black Sapphire Metallic
DCT box with competition pack
Audi R8 4.2 Quattro¦ Grey metallic
6-speed manual
107's : Drexler LSD
6-speed manual
Number 5 means that he doesn't take the roof right out , not the motor .DLH wrote:He certainly does take it right out and positions it in the same place as you did, held in with ties and then a carpeted cover fitted.Number5 wrote:I suspected that the chap up there doesn't take it right out, hence the amazing price he manages !.olsonn wrote:That looks good if you know how to take the roof out, when I had mine done in Durham, didn't need to take the roof out, it was carried out with the roof still in situ
- David-H
He doesn't take the roof out at all, just the tray in the top of the boot.Dietcokeman wrote:Number 5 means that he doesn't take the roof right out , not the motor .DLH wrote:He certainly does take it right out and positions it in the same place as you did, held in with ties and then a carpeted cover fitted.Number5 wrote:
107's : Drexler LSD
6-speed manual
107's : Drexler LSD
6-speed manual
Yes.... that's what number5 saidDLH wrote:He doesn't take the roof out at all, just the tray in the top of the boot.Dietcokeman wrote:Number 5 means that he doesn't take the roof right out , not the motor .DLH wrote: He certainly does take it right out and positions it in the same place as you did, held in with ties and then a carpeted cover fitted.
- Number5
I dont know whether he does or not (take the whole roof out). I'm only going on the info here, but I dont know how he does it for £80. However, fair play as everyone is happy with the job he does.Dietcokeman wrote: Number 5 means that he doesn't take the roof right out , not the motor .
I can get the roof out in about 1 hour, but you loose another hour or so messing with the motor trying to revive it and also clear the drains. It takes about 3 hours or so to get the roof back in neatly and then there's the false panel to make and all the tools to tidy up, so with coffee break half way, it takes about 6 hours in total. (plus parts of it are a two man job), so it's a fair task !
On top of that, there's stocking of the board & carpet to make the panel and hydraulic fluid for top ups. Then consider the liability if you bugger up someone's car or paintwork in the process !
BMW Charge £700-£800 I believe
Porsche Boxster GTS
Previous Zs
Stratus E86
G29 30i
1x Imola Z4MR
Alpina #019
2x E89's
Porsche Boxster GTS
Previous Zs
Stratus E86
G29 30i
1x Imola Z4MR
Alpina #019
2x E89's
- David-H
It takes Dave less than an hour, including clearing drains, fitting the cover etc, with the help of his son because he has done it so often and optimised the way he does it I guess. He sure is thorough and does a great job for £80!
107's : Drexler LSD
6-speed manual
107's : Drexler LSD
6-speed manual
Well I'm the same as number5 , first one ( my own ) took me ages as it was a learning curve and I had the roof out completely. The second one took less time obviously but I was extra careful as it wasn't my car. The next after that was my first relocation job and again was a learning curve , but was completed in about 6 hrs , since then I've got it down to around 4 hrs if it all goes well, that's motor and casing removed, motor revived, relocated and all the drains cleaned and checked . i see it as a challenge more than a job, I enjoy seeing people's reaction when the dead motor is brought back to life and there car roof works again .
I know I'm sad
I know I'm sad
