Genius! Thanks for the top tip! For the full story, airbag light appeared after changing the passenger side window regulator. Even after disconnecting battery (apparently disconnected battery has to be left alone for 30 mins to allow airbag unit to discharge before commencing work on window regulator). Sigh. One problem follows another.
Bought a Creator 310. Plugged it in. Couldn’t find a fault. Worked out engine has to be turned on, after you plug in. Sub directory for e85, body, srs airbag. Found a fault. Erased that fault. Airbag light still showing. Sigh.
Found this thread, went back, searched e85, body, b pillar passenger side. Found a fault. Erased it. No more airbag light!
Smug feeling. Resist urge to search car for other faults and possibly end up creating a new one. Pack Creator 310 away in glovebox. Coffee.
Code Reader/Reset Tool
- maxman
I bet that coffe tasted twice as good as normal
- DSGRNMCM
Evening, any Z4M owners have a hand held scanner? does the C110 work?
E86 Z4m Coupe - Titan Silver, Stubby, Sun protection, Eibach springs, LED interior lights, CDV delete, Badge delete, Pipercross, Exhaust bypass
F11 520d, E46 328i, E91 320d, F21 120d, E46 318ti
Mk VI GTD DSG (Daily Hack)
Just cleared my airbag code using the C110.
Just got rid of mine after years of it being on with C310+
Was ready to give up until I saw the post about the B Pillar, thanks so much!
2003 Sterling Grey 2.5i - RHD car living in a LHD country.
