Sticky Steering now FIXED!!!!!!!
Well having had a few days of scorching temperatures I'm now happy that my sticky sreering is FIXED.
What did I do;
step one Indy upgraded ECU software to latest version - distinct but small improvement,
step two Greased upper and lower U/J's on lower steering column - distinct but small improvement,
step three Greased upper and lower U/J's on lower steering column again and again - distinct but small improvement,
step three Had grease nipple fitted to worm gear box on steering column - definite and very noticeable improvement.
Car parked in direct sunlight for the last week or so getting very hot, up to 30 degrees showing on display.
No stiffness at all - a result thanks to all those on here who gave advice and guidance
Thank guys
Norman
What did I do;
Thank guys
Norman
Re: Sticky Steering now FIXED!!!!!!!
Would love a pic of the location of the grease nipple fitted to the worm gear box on the steering column.
Bumpy
Bumpy
Send me your email address and I'll send the 'instructions' I gave to my local mechanic to fit it, includes photos etcBumpy wrote:Would love a pic of the location of the grease nipple fitted to the worm gear box on the steering column.
Bumpy
- Grumpyowl
Do you know what grease they used ?
I've sent you a PM regarding this. My car is near undriveable at the moment with this problem, in the morning fine but by the afternoon after it's been sitting in the sun a total nightmare.
Sorry noGrumpyowl wrote:Do you know what grease they used ?
Norman has some very useful information regarding this issue and a possible fix. Unfortunately for me a new steering column was the answer, waiting with baited breath until the car returns to what will hopefully be a whole new driving experience.
I would advice anyone buying one of these to at least take the car for a 2 hour test drive, with my fault it would always start with normal feeling steering but after about 1 hour drive the steering would stiffen up considerably. When the steering did work I was actually quite pleased with the feel/weight, seemed to have less "slack" than BMW hydraulic systems.
Can I get the instructions to get this fix in place ?
Lost in space, found in a dustbin........
2005 Z4 2.2
2011 318 d Estate Recalled and repaired - Update: Turbo blown new one about to get fitted....
2008 2.0d Mondeo Estate Gone but not forgotten
2008 TDV6 Discovery 3 HSE
2005 Z4 2.2
Send me your email address and I'll send the 'instructions' I gave to my local mechanic to fit it, includes photos etcNelly Welly wrote:Can I get the instructions to get this fix in place ?
Could you also pm me a link for this fix.
Its on my PC so if you PM me your email address and I'll send the 'instructions' I gave to my local mechanic to fit it, includes photos etcwowser wrote:Could you also pm me a link for this fix.
Update -
Had a new steering column and lower UJ fitted at BMW. Like having a completely different car, can't believe I didn't get it done sooner!
Out of curiosity how much did it all cost?Babw wrote:Update -
- VENDAR
It was fairly expensive, the column itself was £2150, UJ £150 and about 4 hours labour to fit and code. Not much change fromnfarmer wrote:Out of curiosity how much did it all cost?Babw wrote:Update -
£3000.
