Roof lining clips/fixing broken - interior sagging
Mr_Blue_Sky
Post by Mr_Blue_Sky » Sun Oct 21, 2012 3:36 pm
Hi
Noticed today that the roof lining nearest the window is sagging, and is catching slightly on headrest when opening and closing. I peered inside and can see that the plastic bar that is screwed to the upper lining has broken, as per pics below (you can see the screw and the plastic that is split):
Screw that is supposed to hold lining in place:
Plastic that is split, and not being held in place by screw (you can see split above hole):
Now what do I do here? Do I attempt a superglue fix, or is there a part that and Indy could fix? Advise please!
Jamie
3.0L 2003 Merlot Red, DICE, Stubby, 105's, Throaty Roar
dmo
Re: Roof lining clips/fixing broken - interior sagging
Post by dmo » Sun Oct 21, 2012 5:23 pm
The roof lining on mine dropped an inch near the back windows after a huge pothole. It was supported by clips so just forcefully pressed it into place.
BMW Z4 3.0si Sport Coupe (AUTO) (2006), Silver Grey FOR SALE
Mr_Blue_Sky
Post by Mr_Blue_Sky » Sun Oct 21, 2012 6:12 pm
dmo wrote:The roof lining on mine dropped an inch near the back windows after a huge pothole. It was supported by clips so just forcefully pressed it into place.
I think the plastic split is just that bit too wide to prevent it staying securely in. I think superglue and patience is the only way to fix this.
Bing
Post by Bing » Sun Oct 21, 2012 6:37 pm
Mine is like this. Someone on here drilled anther small hole in the plastic, removed the screw and used a cable tie to re-join the bits. Seemed to work a treat, keep meaning to do it with mine. That said, srhutch reckons there is a BMW repair kit you can get from the stealers, but I keep forgetting to ask them when I pass. Theme developing here :oops:
Current... Silver Grey ///M Roadster, non-flimper spec, Imola Red nappa, permanent ear-to-ear grin 8)
andysat
Post by andysat » Sun Oct 21, 2012 6:40 pm
Or a group buy for repairing sagging bits :)
Gone but not forgotten.
New ride silver e93.
Mr_Blue_Sky
Post by Mr_Blue_Sky » Tue Oct 23, 2012 6:03 pm
Good old Darren Wood Indy's, while they were fixing my door membrane repair, they fixed up 3 of the 6 screws that were bust, and told me how to do the rest if they need it (half open roof, unclip front trim, unhook inner headlining and thus the screws are easy to get to, and can be repaired as needed). So grateful for a Indy with morals.... :D
Ziggystardust
Post by Ziggystardust » Sun Jul 22, 2018 7:28 pm
guys do i need to remove the top just to change my headliner?
G600
Post by G600 » Sun Jul 22, 2018 8:39 pm
Ziggystardust wrote: Sun Jul 22, 2018 7:28 pm guys do i need to remove the top just to change my headliner?
I'm not sure about replacing the headlining but if you want to repair the fixing as above you can part open the roof and take apart the front part of the roof to get in.
E85 3.0
Kamuela
Post by Kamuela » Mon Jul 23, 2018 3:51 am
Someplace there’s a thread on this. I fixed mine by opening up the front part of the top ( half a dozen screws, including two semi hidden on the side of the plastic front thing) and drilling new holes through the snapped off ends and re-screwing the end pieces to the middle roof rib. Super easy, no gluing or messing with cable ties. Once you get that front plastic cover off, you’ll see what needs to be done. The only tricky part is not dropping the two flathead torx screws on the sidesof the plastic cover. The roof has to be partway up to access them. Wish I had taken pics, it was so easy and obvious.
paulc_bkk
Post by paulc_bkk » Sun Feb 17, 2019 9:24 am
Thread resurrection
I had a bunch of broken pieces and it looked like someone had tried a repair before...
I used superglue to close the splits, but also used superglued tape to reinforce the join
I then filled the holes with epoxy - I really didn’t want to have to do this again
Then redrilled holes slightly to the side of the originals and reattached to the bow.
Good as new (I hope)
Hope the pics can help other people visualise what’s involved in this fix. Many thanks to everyone who posted before as this thread is what inspired me and gave me confidence to tear the roof liner apart
CrazyOneToo
Post by CrazyOneToo » Tue Jan 07, 2020 10:09 am
paulc_bkk wrote: Sun Feb 17, 2019 9:24 am Thread resurrection
Hello fellow Z lovers,
Is there a DIY somewhere that includes a "how to" for taking the headliner loose from the front area?
I recently replaced my top and the new tops headliner got ripped at the rear corners (due to sagging?)
It could have been from snagging the metal body from the rear trim not being in place when I tried out the new tops functionality.
When opening and closing I noticed it was bunching up at the rollbars but caught it and adjusted it most of the times. Most!
I just want to somewhat repair the rip or install a new one if either is not an incredibly difficult task.
Thanks for any help.
2007 E85 Z4 3.0Si Roadster with 6 speed manual...
2002 E53 X5 3.0i with auto...
1999 E46 328i sedan with auto...
:driving:
dgmx5
Post by dgmx5 » Tue Aug 11, 2020 7:20 am
CrazyOneToo wrote: Tue Jan 07, 2020 10:09 am Hello fellow Z lovers,
Here you go:
viewtopic.php?t=77459
CrazyOneToo
Post by CrazyOneToo » Tue Aug 11, 2020 10:16 am
dgmx5 wrote: Tue Aug 11, 2020 7:20 am
Here you go:
Excellent. Thank you so much!!!
:driving:
