Here's how I did it:dan425 wrote:Thanks, I'll keep on at it after this weekend once I'm back to the Zed!
1. ignition on (last position before starting but I'm not sure does it really matter...)
2. Press and hold window down. When window reaches the bottom, push the button 3 times (1 elephant, 2 elephant, 3 elephant)
3. Press and hold window up. When window reaches the top, pull the button 3 times (1 elephant, 2 elephant, 3 elephant)
4. then do the 15 cm lowering and closing as I wrote earlier (actually I tested it again and now I lowered it around 3 cm and it worked, so it propably doesn't matter is it 5 cm or 12 cm ).
Good luck !
