WHSinTgr8r wrote:Like Curtis said.. it's pretty normal if you are shutting down in neutral with clutch disengaged (out).
I don't really notice it much myself, because my habit is to shut down with clutch engaged (in).
Clutch clatter/rattle
- Caddyshk
Re: Clutch clatter/rattle
2006 Z4MC IB - LL93158
SS Race M, RE X Pipe, FS Headers/DFK Sec 1, OE STB, DZ CDV, AS SS, GC CoilOvers, SP FCAB, RE RTAB, VT Engine Mts, Stoptech lines, Hawk DTC, RE Clutch Stop, RE Tran Mounts, LeatherZ MSB, Tekarbon Spoiler, CF Grills, Advan RS
Its normal, press in the clutch and you dont hear anything. if your not parking the car in a quiet garage you may not hear it...
03 3.0i, 03 AMG E55
- channy106
Thanks all. Puts my mind at ease.
If it gets more pronounced then it must be a problem. If it's normal then I'm happy again.
15 15 Z4 E89 35is Mineral White
13/15 63 640d F13 MSport, Alp/White
12/13 Z4 E89 3.0i, Sp/Grey
11/12: 57 Z4C E86 3.0si Sport, T/Silver
10/11: 57 335i E93 Aegan Blue
09/10: 07 320d E92 S/Graphite
08/09: 06 Z4R E85 3.0si Sport, T/Silver
I’m about to replace the clutch kit and DM Flywheel because of this. Should I even bother?
Now: Z4MC Titan Silver
Gone: E86 3.0Si Sport Titan Silver - M exhaust + bumper - Battery Relocated - Aero Front
E86 3.0Si Sport Silver Grey - Carbon Diffuser - Aero Kit - B/Box Mod - Storm MW V2
E85 2.5 Si Sport Titan Silver
If it was happening in 2008 with cars that were only two years old I wouldn't worry, mine makes the same noise and it's an 08 with 74k on it, funnily enough so did my other halfs Mini Cooper S and that also had a DMF.
Hmmm that’s kind of a relief. I still might replace the clutch and have a look while it’s out. I’m on 78k now. Cheersthecookie125 wrote: ↑Sat Aug 04, 2018 9:39 amIf it was happening in 2008 with cars that were only two years old I wouldn't worry, mine makes the same noise and it's an 08 with 74k on it, funnily enough so did my other halfs Mini Cooper S and that also had a DMF.
- mr wilks
Ive had a couple of Si manuals around 90k that had a DMF noise that went away when clutch was depressed ,both drove fine & changed gear sweet with no clutch slip , my indy said the noise was most likely there for the last 50k & would most likely last another 50k so i just lived with it . Never had it with the 2 auto Si coupes i had thoughDoddsy wrote: ↑Sat Aug 04, 2018 2:51 pmHmmm that’s kind of a relief. I still might replace the clutch and have a look while it’s out. I’m on 78k now. Cheersthecookie125 wrote: ↑Sat Aug 04, 2018 9:39 amIf it was happening in 2008 with cars that were only two years old I wouldn't worry, mine makes the same noise and it's an 08 with 74k on it, funnily enough so did my other halfs Mini Cooper S and that also had a DMF.
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
current Bmw 6 Gran Turismo
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
You might as well replace at the same time as the clutch, save doing the job again.
Tired engine mounts will allow a rattle as the engine stops, since replacing mine I no longer have a rattle on turning off the ignition.
Cheers for the advice lads
As others have said, it's just DMF noise. My 2007 Coupe which I bought over 2 years ago, has made this noise since I got it-I was worried to begin with, but, research shows that most do it and even spending £££ on a new unit, the noise soon returns!
I've driven 13000 miles since purchase, car still engages gear fine, no clutch slip, so just except that's how it is!
