Part ID
domsz4
Part ID
Post by domsz4 » Sun Sep 19, 2021 11:42 am
Can anyone help with IDing these parts.
Got really poor idle when starting, a little searching indicates to check out inlet hoses and any vacuum parts. My problem is pretty obvious tbh.
Just could do with some help id the part numbers
Just after the air inlet 90deg bend and I’m guessing just before it connects to the throttle body there is a small take off with an 8mm pipe guessing this is to the fuel pressure reg. this is stalled off. Also in this area is an other tube heading directly towards the engine that is split. You can clearly see the tube going to the hard line over to the master cylinder vacuum is a also totally squashed.
Proud Whip owner ;)
TheDan
Part ID
Post by TheDan » Sun Sep 19, 2021 12:16 pm
In terms of the pipe that's split, its likely this one (the part of #5 that heads off towards #6):
13547514867
I have assumed you have the 3.0 as you have a sound generator pipe.
domsz4
Part ID
Post by domsz4 » Sun Sep 19, 2021 1:02 pm
Thanks …couldn’t get into realoem for some reason.
After more poking it’s deffo part number 5. Both the elbow and the corrugated bit are pretty much completely snapped off! No wonder I’m getting those P codes.
The piece of deformed vacuum pipe is proving to be expensive or elusive.
Proud Whip owner ;)
