Right ok then.BMW Z4 2.5I SE 2004 wrote: ↑Mon Aug 02, 2021 3:40 pmHi thanks enuff zed. It wouldn't work so took it to have the module replaced. However after replacement the Centre locking button still not working nor the key. The mechanic asked if i had another key to which i said yes. A brand new key. He then tried to code to car through think he actually turned car on and pulled out and done the clicks on fob and suddenly the door locked and unlocked. Now for the weird part as we bring the door close to the closing it works untill right before you close the door and it doesn't work. After this i tried few days later and even that didn't work anymore with door open. Now yesterday which please if someone could explain i was trying to code that same key to car as i was told this might be the problem. My key now no longer works for anything. Thats the roof the bootenuff_zed wrote: ↑Mon Aug 02, 2021 3:30 pm Just reading back to try to understand further: you say the central locking button doesn't work either?
If that is the case, why has focus fallen on the key? That button is separate and I would think it therefore points to something other than a key issue? GM5? Wiring? Was the GM5 replaced because you had the problem or did it appear after that?
It seems the issue is a little clearer now. Please don't read this as a criticism but your title may have misled people a little?
I am no expert with this, so wouldn't try to diagnose for you, however, now we understand that the central locking button wasn't working either before you started replacing stuff, maybe someone like colb may be able to help further.
I would just add that no-one on this forum would intentionally make things worse for you and it is unfortunate that you are now worse off than you were before the suggestions started coming in.
Fingers crossed, with the added understanding, hopefully you can get more help.
