Z4 E85 3.0 - 2005 - will not start!
- Zulu4
Don't think it will be a key problem if the engine doesn't turn over.
Edit: ignore this. See below from colb.
2007 3.0si Auto Sport Roadster. Whippy.
Previous:
2003 3.0i SE Roadster. Whippy.
Previous:
The battery I tried jump starting the Z4 was for a smaller car (1500cc), therefore I’m going to try the larger battery tomorrow. I will update this forum when I know more.
Let’s hope I can get it fixed soon...thanks again guys!
- Zulu4
Battery size for jump starting shouldn't really matter if the other car has its engine running as you will have the power of the two batteries and the other car's alternator producing 14v.
Previous:
Previous:
- colb
If you are certain the starter motor is ok I would suspect that the key is not being recognised by the EWS system in order to release the starter. This could be caused by the key itself loosing the transponder inside if its not an original key and its been apart or the ignition barrel ring aeriel that reads the transponder when the key is inserted has failed in some way. The key should be able to be read by a locksmith or by yourself using an AK90+ key coding machine available on ebay. That is also capable of coding a key but in my experience its a hit and miss proceedure, I didn't manage it but others have coded keys ok. Some diagnostic code readers also have the ability to check the keys they read the key when they are in the ignition, if the aeriel is duff then it wont see the key in diagnostics. Diagnostics can also look at the EWS module and see what it is doing e.g. is it accepting the key that is in the ignition.
Z Shed Cymru member
1999 1.8 Z3
2003 2.5 Z4
1998 Honda Deauville 650
1999 1.8 Z3
2003 2.5 Z4
Still put my money on the starter motor if jumping from another car produces no results. Bench testing the starter will not prove it works under engine forces
+1. and failing motors tend to work intermittently, until they fail completely.
2003 Maldives Blue 3.0i auto
- BumpyZ4
I had the same issue a while back and I SYNCed my EWS & DME with INPA and solved my problem.colb wrote: ↑Fri Jul 23, 2021 9:09 pm If you are certain the starter motor is ok I would suspect that the key is not being recognised by the EWS system in order to release the starter. This could be caused by the key itself loosing the transponder inside if its not an original key and its been apart or the ignition barrel ring aeriel that reads the transponder when the key is inserted has failed in some way. The key should be able to be read by a locksmith or by yourself using an AK90+ key coding machine available on ebay. That is also capable of coding a key but in my experience its a hit and miss proceedure, I didn't manage it but others have coded keys ok. Some diagnostic code readers also have the ability to check the keys they read the key when they are in the ignition, if the aeriel is duff then it wont see the key in diagnostics. Diagnostics can also look at the EWS module and see what it is doing e.g. is it accepting the key that is in the ignition.
2003 E85 3.0i Sterling Gray
KLR 650
Diva Roadster (Kit Car)
KLR 650
Thanks again for your support, suggestions and shares experiences. A local auto key specialist has tested both keys in his workshop, and kindly visited the Z4 at my son’s house today in Burton. The keys are OK, and not cause of problem...keys & ECW box have been tested by locksmith using electronic device.
We have ensured engine is not seized, by turning the crank with a socket & extension bar.
We are going to buy a new/remanufactured starter motor and try that later this week. I had assumed starter motor was OK, as it worked on the bench, but I now uncertain, as a couple of comments on forum suggest it may be an intermittent fault, and may not work under load on the car.
We appreciate your help!
- bigwinn
Keep us posted bud- will help us all learnknmstag wrote: ↑Tue Jul 27, 2021 7:50 pm Thanks again for your support, suggestions and shares experiences. A local auto key specialist has tested both keys in his workshop, and kindly visited the Z4 at my son’s house today in Burton. The keys are OK, and not cause of problem...keys & ECW box have been tested by locksmith using electronic device.
EWS Delete PM me
Coding- airbags etc PM me
EWS Delete PM me
- enuff_zed
Well this is turning into a saga, and gutted we can't help.knmstag wrote: ↑Tue Jul 27, 2021 7:50 pm Thanks again for your support, suggestions and shares experiences. A local auto key specialist has tested both keys in his workshop, and kindly visited the Z4 at my son’s house today in Burton. The keys are OK, and not cause of problem...keys & ECW box have been tested by locksmith using electronic device.
Finger crossed you get it sorted soon.
I would go as far as donating money to the migrants crossing the Chanel if it wasn't the starter motor.
- enuff_zed
Me too, but only for the southbound leg.
- Huzee4
Steve
E85 2.5 SE Maldives blue
E89 20i Estoril blue
I fitted a new starter motor today!
The good news is that engine is now cranking, and sounds promising...however car still will not start!
I removed the spark plugs, expecting them to be soaked with fuel, but they were all bone dry!
The plugs were in poor condition and should have been replaced long ago. It still would not fire up!
I can only assume it’s now a fuel starvation problem.
I don’t understand why this has developed, since the starter motor failure. Any further suggestions to resolve this saga please? Do I need to consider fuel pump & filter? - which is likely to be very awkward to access...
Thanks for your continued help.
Kevin Murray
Kevin Murray
- enuff_zed
Well the starter is a positive step anyway.knmstag wrote: ↑Sun Aug 01, 2021 9:54 pm I fitted a new starter motor today!
Kevin Murray
Have you checked the fuses? Just wondering if you may have blown one for the fuel pump while you were trying to start it?
Could also do with checking for any fault codes.
