Air bag light
Air bag light
Hi all, I've been moving my passenger seat back and forth quite a bit when i was doing some work on my handbrake and now my airbag light is on. I've heard that it's a common issue when moving the passenger seat and is just caused by a loose connection under the seat, is that right and, if so, which cable will be loose? And do i need to reset the light with a code reader once the cable is secure?
- BumpyZ4
Air bag light
First thing to do is read the codes to determine which airbag is setting off the light.
2003 E85 3.0i Sterling Gray
KLR 650
Diva Roadster (Kit Car)
KLR 650
Air bag light
Ah right, I'll do that first. Cheers
- Zulu4
Air bag light
There is only one connector block under the seat with multiple wires running through it. If you move the seat all the way back you should be able to see it.
2007 3.0si Auto Sport Roadster. Whippy.
Previous:
2003 3.0i SE Roadster. Whippy.
Previous:
