Water ingress into boot pocket through rear light cluster
Smallsy99
Post by Smallsy99 » Tue Jul 13, 2021 6:16 pm
Hi there, First time posting as I now have an ‘04 E85
Just had my Z4 for a month now and have just got around to sorting the leak in the boot (right rear pocket and battery compartment). After some tests I have found that when water runs off the roof and into where the boot tucks in, water goes straight down and drips down through the rear light cluster and out and over the brake light connector.
Any help would be much appreciated!
This is where the water gets in
This is it’s route down
Doddsy
Post by Doddsy » Tue Jul 13, 2021 6:28 pm
Could be a few things. On my E86 the light cluster was cracked on the white inner section ( probably not this)
Could be the plugs that the screws go down into from the plastic cover that sits above the light cluster
Or possibly the foam seal
Hope this helps
(My bad your photo didn’t load until after I posted this. I would still remove the lamp cluster and check the foam seal and also for any cracks in the top of the unit. )
Now: Z4MC Titan Silver
Gone: E86 3.0Si Sport Titan Silver - M exhaust + bumper - Battery Relocated - Aero Front
E86 3.0Si Sport Silver Grey - Carbon Diffuser - Aero Kit - B/Box Mod - Storm MW V2
E85 2.5 Si Sport Titan Silver
Smallsy99
Post by Smallsy99 » Tue Jul 13, 2021 6:35 pm
I shall get on and remove this, just need a big enough screwdriver! I want to see what’s happened. At least now I know where it’s coming in. Many thanks
Smallsy99
Post by Smallsy99 » Wed Jul 14, 2021 8:41 am
So I removed the rear light cluster and the nuts were basically loose. So after removing all the bolts and tightening them up again. I think the issue has been solved!
