Help !! Cant get pressure to stay on brake pedal
1536Z4
Post by 1536Z4 » Wed Jun 09, 2021 10:53 pm
Jakg wrote: Wed Jun 09, 2021 10:35 pm If you go to "Functional Jobs" you should be able to scan for all available modules for your car and see if there's anything else you should be scanning instead.
Ok I will try that .
Thanks Jakg
Montego Blue E86 . MILV`s . Simpson Custom Manifold Race Exhaust . xHP transmission stage 3 . VT engine mounts . BC RA coilovers . H&R arbs . Adjustable rear camber arms . Ultra Racing front strut brace . Drexler LSD .
colb
Post by colb » Wed Jun 09, 2021 11:09 pm
Its a matter of choosing the right programme for the module fitted to your car, good advice from Jakg to scan all the modules and make a list of whats in your car. You could try each one presented in the list it will either load it or as you found out reject the job as its the wrong programme for whats in your car, you won't break anything doing it this way. If you find the German scripts annoying consider buying BMW Scanner 1.4 also available on ebay for low cost. It is far easier to use than INPA and its all in English. I recently had an airbag light and despite trying to reset it using INPA and BMW Scanner 1.4 I just couldn't get it to go out. DEcided to invest in a Creator 310+ via an Amazon supplier as a lot of members on here have good things to say about it. Once delivered plugged it in and found the B pillar Satellite sections and cleared a code that came back, light went out and has stayed out. Handy kit to have and less faff than breaking out the laptop all the time. Will still use INPA and BMW Scanner as both have their merits.
Z Shed Cymru member
1999 1.8 Z3
2003 2.5 Z4
1998 Honda Deauville 650
1536Z4
Post by 1536Z4 » Thu Jun 10, 2021 1:08 pm
colb wrote: Wed Jun 09, 2021 11:09 pm good advice from Jakg to scan all the modules and make a list of whats in your car.
Thanks for the info . Unfortunately I don`t get the option for functional jobs and searching the internet there have been a few people with the same issue but I haven`t yet found a solution . The INPA etc I got was from a link provided by the cable seller . The link goes to a Mikes tools download . I have deleted everything from my laptop and run the cleaner and installed it all again but with no change . When I look on the internet people have E85/E86/E89 as options to select and more than one dsc to select but my version of INPA just gives E85 which shows E85 V1.11 and one DSC which is DSC MK60 . Do you have a link to the INPA that you are using or am I being a complete arse :?
1536Z4
Post by 1536Z4 » Thu Jun 10, 2021 2:09 pm
1536Z4 wrote: Wed Jun 09, 2021 10:53 pm Ok I will try that .
Jakg
Post by Jakg » Thu Jun 10, 2021 3:27 pm
1536Z4 wrote: Thu Jun 10, 2021 1:08 pm Do you have a link to the INPA that you are using or am I being a complete arse :?
BimmerGeeks Standard Tools
https://www.bimmergeeks.net/downloads
1536Z4
Post by 1536Z4 » Thu Jun 10, 2021 3:33 pm
Jakg wrote: Thu Jun 10, 2021 3:27 pm BimmerGeeks Standard Tools
By coincidence I have just looked at that site and dowloaded the files . Just need to get an app to unzip the 7zip as it seems my windows zip has expired .
Jakg
Post by Jakg » Thu Jun 10, 2021 3:34 pm
1536Z4 wrote: Thu Jun 10, 2021 3:33 pm and dowloaded the files . Just need to get an app to unzip the 7zip as it seems my windows zip has expired .
https://www.7-zip.org/
1536Z4
Post by 1536Z4 » Thu Jun 10, 2021 3:37 pm
Jakg wrote: Thu Jun 10, 2021 3:34 pm https://www.7-zip.org/
B';##dy Hell give me a chance :rofl: :rofl: :thumbsup:
Thanks again . I will report back .
1536Z4
Post by 1536Z4 » Thu Jun 10, 2021 8:06 pm
Yes Yes and Yes :happyclap: :yeah: :cheers: :bow: INPA is now working properly and a lot more info available !!! If anyone is having problems the same as I was try the download from bimmergeeks . It is a little bit more involved than the others I have tried but if you follow the read me text that comes in the download you should be fine .
Now what did I want INPA for :?
1536Z4
Post by 1536Z4 » Sat Jun 12, 2021 11:06 am
Rucky wrote: Sat Jun 05, 2021 8:25 am I am still looking for a solution to getting rid of VMWARE
This is a fairly recent post have you tried this ?
https://kb.vmware.com/s/article/2010137
Hope it works :thumbsup:
1536Z4
Post by 1536Z4 » Sat Jun 12, 2021 11:09 am
patriot66 wrote: Thu Jun 03, 2021 11:48 pm I used to have an old Gunson Eezibleed and this new one is a huge improvement
Bought one of ebay and as you said a much better product . Got it for £35 which was a bonus .
Thanks :thumbsup:
1536Z4
Post by 1536Z4 » Sat Jun 12, 2021 11:14 am
Brakes working fine now after using new pressure bleeder and a working version of INPA . Thank you to all for your help and advice . Obviously I had to cancel the booking for the geometry set up but have been able to get it booked back in for about 3 weeks time :thumbsup:
patriot66
Post by patriot66 » Sat Jun 12, 2021 11:24 am
1536Z4 wrote: Sat Jun 12, 2021 11:09 am
Thanks :thumbsup:
Happy days ! :D :thumbsup:
Rucky
Post by Rucky » Sat Jun 12, 2021 10:59 pm
1536Z4 wrote: Sat Jun 12, 2021 11:06 am
Thank you I will give it a go.
04 2.5i Titan silver - 1st Z4 now sold on
07 3.0si Silver Grey M Sport pak.
X5 and assorted motorbikes
Rucky
Post by Rucky » Sun Jul 11, 2021 7:09 pm
Removing VMWare Player from Windows 10 after installing INPA
I finally found a solution to removing VMWare player so that I could update Windows10.
This is what is needed fo anyone who has a similar issue.
MicrosoftProgram_Install_and_Uninstall.meta.diagcab
iInstalling from the BCable Diagnostics software package inclused VMWare Player but no uninstall is provided : BEWARE
