Engine leaks
Engine leaks
I’ve viewed an e86 that could have potential but has some signs of oil leaks.
So around the oil filter housing and then ‘sprayed’ onto air box and the other side and also a stained area on the undertray.
I know the oil filler housing gasket is prone to going and the surrounding area I suppose would be concurrent with the oil everywhere.
Except there are also oil stains around the block, exhaust side.
It seems to run done from the head gasket area for the first few cylinders.
Could this have been blown from the oil filler gasket also? Are there other possibilities.?
I’ll try to include some photos I took.
Thanks.
Thanks.
Z Coupe 3.0 si
Audi A2
Eunos Roadster RS ltd
Previous BMW’s
E36 328i ACS Sport Touring
E21 323i
Audi A2
Previous BMW’s
E21 323i
Engine leaks
Z Coupe 3.0 si
Audi A2
Previous BMW’s
E21 323i
Audi A2
Previous BMW’s
E21 323i
- enuff_zed
Engine leaks
More likely to be the top cover gasket leaking on the other side isn't it?
Engine leaks
Z Coupe 3.0 si
Audi A2
Previous BMW’s
E21 323i
Audi A2
Previous BMW’s
E21 323i
- rjhl64
Engine leaks
Hi,
As a precaution I would also check the serpentine belt to see if any oil has reached the belt causing the belt to deteriorate.
BMW Z4 SI SPORT Automatic / E86 coupe
Engine leaks
You mean the rocker cover?
The photos aren’t great but I couldn’t see any oil above the head gasket.
Z Coupe 3.0 si
Audi A2
Previous BMW’s
E21 323i
Audi A2
Previous BMW’s
E21 323i
Engine leaks
Yes thanks, I did have a look and the belt looked relatively fresh.
But also the oil sitting in a little well with the OFH maybe wasn’t that old..
Z Coupe 3.0 si
Audi A2
Previous BMW’s
E21 323i
Audi A2
Previous BMW’s
E21 323i
- enuff_zed
Engine leaks
Yeah that's it. I didn't call it a rocker cover as it's not a pushrod engine, therefore no rockers..................and I'm a pendantic tw*t
But yes, that's what I meant.
Engine leaks
Haha yes I’m using vintage terminology!
So as it has a silver plastic engine cover it’ll have the magnesium engine ‘valve’ cover below.
I just looked at a thread where this has been done.
New aluminium bolts and various other seals and gaskets required I suppose.
Is this a know problem. I haven’t seen any leaks on other n52’s or ‘k’s?
Z Coupe 3.0 si
Audi A2
Previous BMW’s
E21 323i
Audi A2
Previous BMW’s
E21 323i
- enuff_zed
Engine leaks
I would have to defer to N52 owners for that tbh.Inline 6 wrote: ↑Mon May 10, 2021 4:19 pmHaha yes I’m using vintage terminology!
- Mr Tidy
Engine leaks
I call it a cam-cover gasket - but I'm sure BMW have invented some other terminology!Inline 6 wrote: ↑Mon May 10, 2021 4:19 pm Haha yes I’m using vintage terminology!
It does happen, although I never had a problem with it leaking on either of my E86s.
But my 330i has an N52 engine and a month or so before I bought it the previous owner had the gasket replaced at 107K miles so it must have been leaking - shame he didn't get the oil filter gasket done as well because it has that same little puddle as your first photo. But that one will be sorted on Wednesday when it has its next oil service.
I don't know, but I imagine a gasket set ought to include anything else you need like new aluminium bolts.
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
- mr.tourette
Engine leaks
Start with the oil filter housing gaskets as they are obviously gone.. they can make quite a mess that ends up all over the engine bay.. then have a clean up and see if any new oil appears, from your pics to me it looks like just the housing filter ones have gone but also it is hard to be 100% just from pics.
