Water pump failure?
- bazza190
Water pump failure?
Having just replaced the rear brake pipes and flexis, the car decided to reward me this morning by starting to overheat. I switched it off about 3/4 up the gauge. Left the ignition on and the gauge started dropping quickly. Settled on normal so drove 1/2 mile, started rising again. Repeated the procedure and made it 1/4 mile home.
Does this sound like an intermittent pump failure?
Level was ok when checked at the weekend. Mileage is 81k, no record of pump being replaced before.
TIA
Barrie
TIA
Barrie
2006 Titanium Silver Coupe ZHP Stubby MM Tips Eibachs Royals Wheel 19" Bola B11s
- mr.tourette
Water pump failure?
I'd be replacing pump and stat if no evidence of it ever being done..it is around that mileage they tend to crap out, most replace as precaution before any symptoms
- bazza190
Water pump failure?
I agree, just want to be sure before I order them. Been an expensive month! I am pretty certain the pump is either intermittently failing or struggling.
Water pump failure?
The electric water pump on my N55 135i (the same system) failed at well under 50,000miles and under 5 years old, but my 130i pump was still going strong when the car was 10 years old. There was a lot of chat about this on BabyBMW and quite a few members stated that their pumps were still going fine at 120,000 miles. Consequently, I'm not sure what service interval we should consider when replacing the pump and stat as preventative maintenance, unless we choose to do so every 5 years...(or less)...or just accept that the bits will fail at some point. Thoughts?
The initial symptoms of pump failure on the 135i were that the radiator fan, which had variable speed control, started whizzing up to max speed and then dropping back down within moments and at unexpected times. Within 30 minutes of noticing this, the temperature started climbing, so I switched off and did as you did, I let it cool down and limped it home very quietly and without cooking it.
E85 3.0si manual
- bazza190
Water pump failure?
Pump and stat ordered, cheapest by far was from Germany even including the expected VAT and customs charges. At least it will be peace of mind if nothing else
- Zulu4
Water pump failure?
If anyone is looking for a really cheap pump, Amazon have a Chinese one for £58 (£71 minus 18% voucher)
https://www.amazon.co.uk/gp/product/B08 ... UTF8&psc=1
I know most people will want Pierburg, but for this price you could replace it 4 times and still be quids in.
You could argue it may not last as long as OEM, but IMO you couldn't get much more unreliable than the Pierburg.
2007 3.0si Auto Sport Roadster. Whippy.
Previous:
2003 3.0i SE Roadster. Whippy.
Previous:
Water pump failure?
Can you share the link, I’m tempted to order and change mine just in case. Thanks
Current cars: 2006 3.0si E85 Sapphire Black, cruise, MFSW.
BMW 535d Touring (F11)
Skoda Fabia 1.2
BMW S1000XR
Skoda Fabia 1.2
BMW S1000XR
- enuff_zed
Water pump failure?
But on the downside, that's four times as many chances of overheating your engine.Zulu4 wrote: ↑Wed Apr 21, 2021 2:21 pm If anyone is looking for a really cheap pump, Amazon have a Chinese one for £58 (£71 minus 18% voucher)
Water pump failure?
Yes, that would be helpful. Whilst mine seems fine i have looked around for a pierburg replacement (2.0 /n46 engine) and whilst autodoc suggest they do, on a google search, i couldn't find one on the site. Any suggestions very welcome...davidmudley12 wrote: ↑Wed Apr 21, 2021 3:21 pmCan you share the link, I’m tempted to order and change mine just in case. Thanks
2.0 m sport (suspension / steering wheel/scuff plates) cupholders sapphire black with factory hard top. Needs a little tlc but loving it.
- Zulu4
Water pump failure?
True.
Anyone on here used a non-OEM water pump to attest as to how reliable they are ?
Previous:
Previous:
- Benderloch
Water pump failure?
E86 Silver Grey Red leather, Piano Black trim.
- Mr Tidy
Water pump failure?
That does look like a good deal.Benderloch wrote: ↑Wed Apr 21, 2021 7:17 pm https://www.ebay.co.uk/itm/254607866699
This looks like a good price ?
The pump died on my 1st E86 at 60K miles but my 2nd was still on the original when I sold it at 91K - lifespan seems to be pretty random!
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
Water pump failure?
Mine was replaced just before I bought the car at 60k miles. Similar to Mr T's above.
E86 In sapphire black
- bazza190
Water pump failure?
That's the one I ordered, should still come in cheaper than a UK sourced one.Benderloch wrote: ↑Wed Apr 21, 2021 7:17 pm https://www.ebay.co.uk/itm/254607866699
- bazza190
Water pump failure?
Pump and stat arrived via TNT this morning, surprisingly no vat/duty/courier charges to pay. So £231 for Pierburg pump and Mahle/Behr stat, delivered is a really decent price!
