My car is falling to bits and I feel powerless :(
So I took my car out of the garage since the weathers getting better. Took the hardtop off and after about 2 days of opening and closing the roof, the motor failed.
My coolant light was on, checked the reservoir and it's almost completely empty. Filled it up and a few days later it was almost empty again and I noticed spots under the car where it was obviously leaking.
Both control arms need replacing (I have the new ones but haven't fitted them yet)
The key has completely stopped working. I did a scan with INPA and it said something about the central locking "Central Locking: Relay does not pick up when locking".
The mirrors only work in 2 directions on both sides.
My handbrake (red) and DSC (yellow) are both on. Carly says it's a wheel speed sensor although it's not completely clear. INPA says only one error in DSC section and says "liquid level switch fault" (translated from German).
Camshaft Sensor pulls up an error that doesn't go when cleared.
I'm at a wits end with all these issues. Starting to wonder if it's worth the hassle in fixing everything as it's an 03 E85 with 85k on the clock.
2003 Sterling Grey 2.5i - RHD car living in a LHD country.
- Chris_D
Time to get your hands dirty mate!
All do-able issues apart maybe from roof-motor.
Build up this thread with progress reports and don't be shy to ask for any advice if required.
Doing these jobs can be hugely satisfying when completed.
- Crazy Harry
Oi! - snap out of it. Its just a few jobs at once if you look at them one by one all are do-able start with an easy one and slide yourself into it. These cars are good for 200+ miles.
There's someone on here who have done each one of these nothing is impossible.
Chin up matey. These moments will come to us all so you maybe able to help someone else out after you've learned to fix them.
- skmattwell
With the mirrors it might be worth persevering with the controls. I thought mine wouldn't go up or down but the directional switch was just a bit lazy. Maybe try pressing a little harder or in a slightly different direction (mine is also an 03' e85 but with 124k on the clock)
Just a thought but a failing battery can cause all sorts of electrical issues particularly if car hasnt been used for some time. I would check the voltages just to make sure it isnt a simple battery problem.
- markplant
Re the mirrors if they only work on both mirrors with the same part of the button on the switch, it's probably the switch
Online
My first car was a 1969 Ford Escort, it was 11 years old when I got it. The floor was a Flintstones copy, and it hated starting.
Your zed is 18 years old and packed with a lot more toys.
Are you that surprised that a few sensors and motors are playing up.
Come on now, many younger model vehicles are already on shop shelves as tin cans.
These are lasting pretty well and will give you many more years, with a bit of maintenance.
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
And if it is the switch as suggested you can pick one up for little expense.
Take a day, show it some love and I'm sure you will be rewarded! Good luck.
Onlineronk
Niggles and a few £'s spend on an old car v New car and a Lot of £'s on depreciation/year - Theres no winning either way its pay up!
- enuff_zed
Switch sounds like an easy fix.
As for the rest, work out a logical order to do it all, read up on it through the forum etc then do one ting at a time and fix that before moving on.
I'd start by ruling out a potential battery issue by the sounds of it.
Then obviously if the key won't work you won't get much further, so sort that.
Don't want to be running the engine with no coolant, so find that leak and get it fixed.
Then when you're able to get in the car, start it and run it without killing the engine, you can start thinking of the other bits.
And every time you've had enough, get on here, tell us where you got to and I'm pretty sure you'll get enough encouragement to carry on.
Or sell me your car for 50 quid
Thanks for the replies guys.. nice to have a bit of inspiration.
I changed the battery when I was having key problems last year. It worked fine for about 2 weeks before completely stopping. I've got a new expansion tank arriving on Saturday so gonna get the car in the air and sort that out.
@Enuff_zed If you want to come to Germany and pick it up, you're welcome to it
- enuff_zed
Ceertainly! Shall I bring some AstraZeneca with me.AC5L4T3R wrote: ↑Thu Apr 15, 2021 1:38 pm Thanks for the replies guys.. nice to have a bit of inspiration.
I'm getting my jab tomorrow
I bought a C310+ and finally cleared my airbag light after 5 or so years. Ive also had the handbrake/dsc light on for a while now and it told me my brake fluid level sensor was causing a problem. I had a look under the bonnet and found my cable almost cut in half.
Any idea how to fix it? It's half way down the cable so no idea what to do.
- 20210429_114412.jpg (71.11 KiB) Viewed 786 times
- patriot66
Cut the wires. Strip 1cm on all the ends. Twist them back together. If the wires aren't quite long enough then splice a short piece in the gap. Fix them permanently with solder. Wrap in black insulation tape.
