Nooo...my first random fault lights
- Z4mal
I’m happy to look into investing into a code reader, any suggestions to an appropriate one?
Current
E85 Maldives blue (fun me)
G26 i4 M50 (the weapon for work me )
F01 730d Msport (gone but not forgotten)
10 other BMWs in my history! Eek that’s a lot of
- Z4mal
Any recommended readers?
Current
- ph001
C310+ from Amazon
Creator C310+ V11.7 Multi System Scan Tool Engine Fault Code Reader Diagnostic Tool https://www.amazon.co.uk/dp/B01MPZTM5Q/ ... FY113HWYRR
- Z4mal
Great thanks I’ll take a look I’ve also been recommended the Autophix 590 which is a little more so going to compare the two and place an order today. I’ll let you know how I get on.
Current
- ph001
Do you mean the Autophix 5900? Currently on offer on Amazon for £67.99 which is good value. I'm not sure it offers a great deal more functionality than the Creator though.
https://www.amazon.co.uk/AUTOPHIX-Multi ... 893&sr=8-2
- Z4mal
Yes that’s the one I’ve placed an order as the offer looked a good opportunity. Should have it by the weekend.
Current
- Z4mal
So my Autophix 5900 turned up early and I reset the faults only for the same to reappear. The fault is as per the image
Current
- ph001
Yep, abs pressure sensor then. You should probably just change both....the Chinese ebay ones work just fine.
- enuff_zed
I do like a nice clear fault identification and easy fix
- Z4mal
Is it something that even a non mechanic like me can do or will I need to get the brakes bled which is way over my capabilities??
Current
- ph001
Cling film over the brake fluid cap opening and screw it back on. Then just whip them out one at a time and screw the new one in as quickly as possible. You will find fluid leakage minimal and no need to bleed brakes.
Good job you didn’t start wasting your time pulling abs sensors from the wheels.
Also be aware to change the second sensor you need to have the first one off the car. I tried to change the sensors one at a time and it didn’t go well; unscrew the first one, unscrew the second then put the new ones on as quickly as possible. And that’s all you need to do.ph001 wrote: ↑Thu Apr 08, 2021 4:46 pmCling film over the brake fluid cap opening and screw it back on. Then just whip them out one at a time and screw the new one in as quickly as possible. You will find fluid leakage minimal and no need to bleed brakes.
- Z4mal
Brilliant thank you for the advice. Just need to find the parts online and I’m ready to give it a go
Current
- Z4mal
New sensor did the trick all done (did it myself !), thanks to ph001 for the excellent advice.
Current
- ph001
