4 yellow lights
4 yellow lights
Update on mine it is off side front sensor cleared code lights are off (for now) but will give it a clean and check the ring when I get the chance.
Bmw z4 3.0i
Africa Twin
Africa Twin
- Rucky
4 yellow lights
There are some photos here on an earlier post
viewtopic.php?f=3&t=126755
04 2.5i Titan silver - 1st Z4 now sold on
07 3.0si Silver Grey M Sport pak.
X5 and assorted motorbikes
4 yellow lights
Quick update on mine. After trickle charging the battery, back to full strength, the lights warning lights were still active.
I went to my Indy today for a minor oil filter leak (new gasket fitted) and they ran a diagnostic check. It wasn't any sensor but the ABS Hydro pump. They had a tinker with it and the lights have gone. Ultimately, it may need a new pump but for now, all is well again.
E86 Si Auto Coupe in Ruby Black.
4 yellow lights
I need a speed sensor the ring is fine cleaned the sensor but looks like i need a new sensor. Is it main dealer or are ebay ones ok.
Bmw z4 3.0i
Africa Twin
Africa Twin
- Rucky
4 yellow lights
If you buy pattern - check length before you fit - see above post
4 yellow lights
After changing the sensor I'm now down to 3 yellow lights from 4. I've now got traction control, handbrake, and low tyre pressure. Scanning says wheel rotation circuit. Any thoughts anyone.
Bmw z4 3.0i
Africa Twin
Africa Twin
OnlineMr Tidy
4 yellow lights
I had those 3 light up a while ago after my battery died.
Took it to Ross at RBM on Tuesday and it was showing a DSC Control Unit fault. I'm pretty sure Ross tweaked the DSC sensor setting (above my level of technologoical competence) and all lights went out. Still out today too.
If it was the Control Unit he said they are about £2K from BMW, but you can send them away for a rebuild for a few hundred (I think the same applies to ABS pumps).
Good luck getting those lights turned off.
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
4 yellow lights
Would anyone know the part number for a yaw rate sensor for a 2004 Z4 e85 3.0 manual. Cheers.
Bmw z4 3.0i
Africa Twin
Africa Twin
- Z4mal
4 yellow lights
Try this feed for some info it may help. viewtopic.php?p=1826749#p1826749
Current
E85 Maldives blue (fun me)
G26 i4 M50 (the weapon for work me )
F01 730d Msport (gone but not forgotten)
10 other BMWs in my history! Eek that’s a lot of
- meh92
4 yellow lights
Had the same thing and it turned out to be my ABS motor/pump. I sent if off to ECU Testing in Derby for a rebuild. Overall, it was a pretty easy job with basic hand tools. ECU had it back to me in a week, and I live in the US!
2007 Z4 3.0si Roadster, Manual Transmission & Sport Package
- enuff_zed
4 yellow lights
Glad it's sorted, and thanks for coming back to update.
4 yellow lights
Just encountered the same issue (all four lights) after driving through a massive puddle this afternoon.
Hoping that a wheel/ABS sensor has just got itself wet and will be OK when the car dries out...though that does beg the question of whether it needs looking at to stop it happening again!
