Anyone had this kind of wheel wobble - Found issue
- Nictrix
We have a slight vibration in our car at about 80 and after investigation we were told that one of the rears has a slight flat spot.
The tyre with the flat spot previously had a puncture repaired in it.
I had the same thing about a month ago
I thought I lost a weight so swapped the spare on both fronts no difference
Turned out to be a seized brake calliper nearly melted my finger print off when I touched the disk
- HU51A_FU
Thanks all for your suggestions will let you know outcome Thursday!
Online
Many years ago I had exactly the symptoms you describe with a TR7, which turned out to be propshaft related. Some part of it wasn’t tightened correctly and dropping down speed it developed quite a severe harmonic vibration, but at other speeds and on the way up it was OK.
2003 Maldives Blue 3.0i auto
- Raj_UK
Don’t know what wheels you have! However I didn’t notice that you said when slowing down. I remember my bro in law had a vibration and noise on his E46 that got worse going up from 40mph. Sounded like a dodgy wheel bearing to me but turned out being a buckled wheel - a 17 inch type 44 if I recall correctly.
Z4less
- HU51A_FU
I think you may have solved it....Raj_UK wrote: ↑Tue Feb 23, 2021 11:13 pmDon’t know what wheels you have! However I didn’t notice that you said when slowing down. I remember my bro in law had a vibration and noise on his E46 that got worse going up from 40mph. Sounded like a dodgy wheel bearing to me but turned out being a buckled wheel - a 17 inch type 44 if I recall correctly.
Not sure if this might help but I had warped discs which caused the vibration on my car.
I had exactly this issue. Random vibration through the steering column at random speeds. Turned out to be a partially seized front caliper. Replaced them both and all is now well. Someone on here had pointed me in the right direction, took the car out for a 10 minute drive and then parked up and touched each wheel, one was noticeably hotter (front left in my case).
$hed has also mentioned this in his post.
Hope this helps.
Hope this helps.
Montego blue 2006 BMW Z4 coupe 3.0si with black interior, ZHP, Whippy, 12mm front/16mm rear spacers on BBS 108's wrapped in Michelin PS4's. :driving:Brand new Pierburg water pump fitted at 101k after failure (should have done it at 100k)
- Raj_UK
Is that for certain? Because I’m hardly ever right!HU51A_FU wrote: ↑Wed Feb 24, 2021 10:05 amI think you may have solved it....Raj_UK wrote: ↑Tue Feb 23, 2021 11:13 pmDon’t know what wheels you have! However I didn’t notice that you said when slowing down. I remember my bro in law had a vibration and noise on his E46 that got worse going up from 40mph. Sounded like a dodgy wheel bearing to me but turned out being a buckled wheel - a 17 inch type 44 if I recall correctly.
Z4less
I had this exact issue and when I got home 2 of my wheel bolts had snapped and the other 3 were loose. Was a shock but at least it was a simple fix. Could be something around the rear tyres such as flat spotting but I think that would be more obvious at various speeds. Good luck though
- HU51A_FU
So Guys,
I had a friend look at my issues yesterday, conclusion is below, explains the pulling to the left and steering issues.
1. Seized NSF brake calliper - Replace £90.00 with Eurocarparts discount + Surcharge on old unit.
2. NSF Lower arm - £114.00
Total = £158.12
3. Renew both rear lower arm bushes that go into subframe as these have slight play, £62.28 + VAT from Powerflex.
If any one can obtain cheaper costs for the above items give me a shout as these issues do need doing of course.
Hopefully this comes in handy if any of you experience same issue.
Total = £158.12
- HU51A_FU
Total bill for anyone who ends up having to do the same thing as me is £370.00 including VAT.
